You would have to install something like nagvis or nagmap. From there it should be fairly straight forward using either their documentation or just the interface.
im having nagmap and my nagmap are workign
but im want to put the text no map
how im can do that ?
sreinhardt wrote:You would have to install something like nagvis or nagmap. From there it should be fairly straight forward using either their documentation or just the interface.
Honestly, I would suggest talking with the developer of nagmap. While we are happy to help with nagios related projects, this isn't one we maintain or see too much. The developers contact info can be found on his github https://github.com/hecko/nagmap
