hi,
My nagios core 3.3.1 has hanged,i get Error: Could not read object configuration data!.
help
nagios Error: Could not read object configuration data!
Re: nagios Error: Could not read object configuration data!
It's likely a configuration error, run /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (or where ever your nagios is installed). If you can't work out what the issue is still from the output then post the errors here and we can assist you further.
- -fno-stack-protector
My thoughts exactly, thanks jsmurphy! Let us know what comes from that command tariqondego.
Thanks guys,I have this sorted.It was a low disk space issue.
