/usr/bin/install -c -m 755 -o root -g root -d /etc/rc.d/init.d
/usr/bin/install -c -m 755 -o root -g root daemon-init /etc/rc.d/init.d/ndo2db
/home/nateh/nagiosxi/subcomponents/ndoutils
NDOUTILS-POST
NOTE: If prompted, enter the MySQL root password
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
ERROR: NDOUtils database install appears to have failed - exiting.
ERROR: Subcomponent 'ndoutils' installation failed - exiting.
Subcomponents installation failed - exiting
RESULT=1
INSTALLATION ERROR!
The script that failed was: './A-subcomponents'
[root@localhost nagiosxi]# Code: Select all
[root@localhost nateh]# rpm -i ndoutils-1.4-0.6.b8.el5.x86_64.rpm
warning: ndoutils-1.4-0.6.b8.el5.x86_64.rpm: Header V3 DSA signature: NOKEY, key ID 217521f6
error: Failed dependencies:
nagios < 3 is needed by ndoutils-1.4-0.6.b8.el5.x86_64
