Disk Space for VM Guests
Justino
Post by Justino »
For all support requests, we need to know:
Version: Nagios XI 2014R1.0
CentOS 6.5
64bit
VMware Image
No special configs
Hi everyone,
I just configured a Host with the "WMware" add-on which was succesfull.
Now i'm trying to add a guest via "VMware" add-on but i can't add the disk space option for my C: drive.
How am i able to fix this?
Kind regards,
Justin
Re: Disk Space for VM Guests
Post by slansing »
You are using the VMWare monitoring wizard, correct?
There may not be an option for the VM's own virtual disk usage, we typically see users run things such as the NCPA or Windows Server monitoring wizard against their windows VM's to get more specific information. Since they are for all intents and purposes just about the same as a physical system, you can get the same information from the accompanying wizards/checks.
