Nagios Support,
We are unable to schedule a downtime in nagios xi, we are getting below error message while scheduling the downtime
ERROR Message :
It appears as though you do not have permission to submit the command you requested...
If you believe this is an error, check the HTTP server authentication requirements for accessing this CGI
and check the authorization options in your CGI configuration file.
END of Error message
Our Nagios version, Nagios XI 2012R2.9
Please advice how to resolve the error and schedule downtime in Nagios.
Regards,
unable to schedule downtime in Nagiosxi
sreinhardt
- -fno-stack-protector
Re: unable to schedule downtime in Nagiosxi
Is your user an admin within the XI interface? The only time you should get this message, is if your user does not have access to see\control monitoring engine, and possibly access to advanced features. But generally being a contact for the item you are wishing to schedule downtime for should be enough.
