Nagios plugins error Return code of 127 ...
fsaunier
Post by fsaunier »
i'm working on Nagios Core 3.3.1.
i'm using check_nrpe to check hosts.
from the client, the configuration is ok:
the functional of plugins is ok, nrpe.cfg is OK:
/opt/nagios/libexec/check_disk -w 20 -c 10 /var
--> DISK OK - free space: /var 28305 MB (98% inode=99%);| /var=396MB;30217;30227;0;30237
from the server:
./check_nrpe -H host_to_check -p 5665 -c check_disk
resource.cfg is ok.
but on the web interface, i have this:
(Return code of 127 is out of bounds - plugin may be missing)
Re: Nagios plugins error Return code of 127 ...
Post by slansing »
Can we see your check_nrpe definition in commands.cfg, as well as your service definition for this check?
