Disk Critical
Metalliogre
Re: Disk Critical
Post by Metalliogre »
I started following this tutorial on how to configure nagios to rid the 'critical disk error' and I am being asked to edit/create a checkcommand.cfg that I can't seem to find/do. Any help would be appreciated!
http://devincharge.com/quick-dirty-setup-nrpe-ubuntu/
Jeremiah Slagle,
JNB Productions
www.YouTube.com/JeremiahSlagle
@JupeBobby
sreinhardt
-fno-stack-protector
Re: Disk Critical
Post by sreinhardt »
That file is likely command.cfg instead of checkcommand.cfg. The naming is entirely arbitrary, but command.cfg is the defualt.
Stuart Watts
Re: Disk Critical
Post by Stuart Watts »
The checks run as user "nagios" and you're attempting to check home directories, which "nagios" probably isn't allowed to traverse. You'd need to add an ACL (if possible) or slacken permissions to check these directories.
Metalliogre
Re: Disk Critical
Edited with no luck.
Jeremiah Slagle,
JNB Productions
@JupeBobby
Metalliogre
Re: Disk Critical
How would I adjust permissions to allow the checks? I'm lost in Nagios.
Jeremiah Slagle,
JNB Productions
@JupeBobby
eloyd
Cool Title Here
Re: Disk Critical
Post by eloyd »
It's not a Nagios answer, I'm afraid - it's an operating system answer. You need to be able to allow the user named "nagios" to check directories that are not owned by the user named "nagios." So you need to allow the user named "nagios" access to the directories using whatever appropriate security mechanism your OS allows.
(I'm saying user named "nagios" to avoid confusion with software called "Nagios.")
Eric Loyd • http://everwatch.global • 844.240.EVER • @EricLoydI'm a Nagios Fanatic!
Metalliogre
Re: Disk Critical
I am running Ubuntu 12
Jeremiah Slagle,
JNB Productions
@JupeBobby
eloyd
Cool Title Here
Re: Disk Critical
Post by eloyd »
EDIT: I didn't realize that this was page 2 of the comments, but I still think we've missed your actual check command and services entry.
I may have missed something, but I don't think we've seen the configuration that shows what the check is you're actually performing. Can you share that with us? services.cfg and checkcommands.cfg would be the default filenames that that information is in.
Stuart Watts
Re: Disk Critical
The fact that these are .gvfs (Gnome Virtual File System?) mounts in home directories makes me think you've got something cool like networked home directories. If that's the case, the fileserver should hopefully be monitored already, so you could simply exclude those mount points from the check?
In your "commands.cfg", find the entry that relates to "check_all_disk". The comandline for this probably calls the plugin "check_disk". That plugin can be configured to ignore a mount point (-x), ignore a type of mount (-X), and even ignore mount points based on a regex (-r). Might be feasible to use one of these to ignore these checks?
sreinhardt
Re: Disk Critical
Nice catch Stuart! Metal could you confirm if this is the case, and provide the current service and command definitions so that we may help you sort this out.
