Not receiving notification emails
tariqondego
Post by tariqondego »
I am not receiving notification emails,even though I have set this up for hosts.The nagios.logs show notification being sent but I am not getting the mails.
Please advise.
Stuart Watts
Re: Not receiving notification emails
Post by Stuart Watts »
What does /var/log/maillog show at the time Nagios tries to send notifications?
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Thanks stuart, that is a great question, as core generally will use the local mailer, that should push email sent to the maillog as well.
tariqondego
This is what mailog says:
nagios exim4: ALERT: exim paniclog /var/log/exim4/paniclog has non-zero size, mail system possibly broken.
Please advise.
Post by slansing »
Is that all it says? Just one line in your current maillog? If so, do you have anything in the archived maillogs in the same directory?
tariqondego
Yes this is all it says,same for the archived logs.
Please see attached and advise.
maillog.zip
(1.09 KiB) Downloaded 181 times
I'm assuming this is on a Debian/Ubuntu system? If so, I'd take a look at these two posts:
http://blog.rebelit.net/67
http://linuxindetails.wordpress.com/201 ... ly-broken/
tariqondego
Thanks @tmcdonald for those helpfull posts.The mail.log is clear now.
But still,when I do a testmail its still unsuccesful,and the maillog remains empty.
See testmail below:
root@nagios:~# mail -v [email protected]
Subject: ola
this is a test ola!!
Cc:
LOG: MAIN
  <= [email protected] U=root P=local S=384
root@nagios:~# delivering 1X6dGZ-0006iC-WC
R: nonlocal for [email protected]
LOG: MAIN
  ** [email protected] R=nonlocal: Mailing to remote domains not supported
LOG: MAIN
  <= <> R=1X6dGZ-0006iC-WC U=Debian-exim P=local S=1257
delivering 1X6dGa-0006iG-3i
LOG: MAIN
  Completed
R: system_aliases for [email protected]
R: userforward for [email protected]
R: procmail for [email protected]
R: maildrop for [email protected]
R: lowuid_aliases for [email protected] (UID 0)
R: mail4root for [email protected]
T: address_file for [email protected]
LOG: MAIN
  => /var/mail/mail <[email protected]> R=mail4root T=address_file
LOG: MAIN
  Completed
please advise.
There's your problem. You must configure the system to allow sending to remote addresses:
http://superuser.com/questions/384499/h ... il-command
tariqondego
Reconfigured exim4,its now ok.
