errno is 2: No such file or directory.. check_mysql
I am facing problem while monitoring Mysql of a CentOS Nagios Client machine. All other services are successfully monitored. I have downloaded check_mysql from internet and dumped in /usr/local/nagios/libexec .
When I run command check_mysql then It gives the following error:
[root@nagios libexec]# ./check_mysql
./check_mysql: error while loading shared libraries: libmysqlclient.so.18: cannot open shared object file: No such file or directory
I have reinstalled plugin, by doing this, it deletes check_mysql file from libexec folder. The same is happening with check_asterisks file.
Please let me know where I am missing. Need this on urgent basis.
Re: errno is 2: No such file or directory.. check_mysql
It looks like you do not have the proper MySQL libraries on your Nagios server. What operating system are you using on the Nagios server? If it's CentOS, try this:
yum install mysql mysql-libs
Thanks for the reply,
Do I need to install this (yum install mysql mysql-libs) on Nagios server or the client Cent OS?
Also, suggest, the same thing is happening to monitor Asterisk service on a client CentOS.
I have run the command on Nagios server "yum install mysql mysql-libs
Below is the output:
Package mysql-5.1.73-3.el6_5.x86_64 already installed and latest version
Package mysql-libs-5.1.73-3.el6_5.x86_64 already installed and latest version
Nothing to do
Please suggest.
Sorry for multiple replies, but I am stuck in this![Sad :(](./images/smilies/icon_e_sad.gif)
Nothing to do
Please suggest.
It needs to be on whatever machine is running the check. If the libraries are already installed, then most likely the problem is due to you grabbing the compiled program from a different host, rather than compiling it on your own server.Do I need to install this (yum install mysql mysql-libs) on Nagios server or the client Cent OS?
If the problem persists, please download the entire nagios plugin source, and build from source on your nagios machine(s). This may resolve the missing library problems.
I am trying from Nagios server only, check_mysql is located in /usr/local/nagios/libexec folder. I have download it separatly from internet.
Kindly share the link from where I can download the entire Nagios plugin source and its installation steps. Also suggest, do I need to remove existing plugin? (please give command).
The information you need is at http://www.nagios.org/download/plugins
Let us know if you run into some issues, while trying to install the nagios plugins. Thanks!
No error found while installing Nagios plugin. still getting same while using check_mysql or check_asterisk .
Still getting same error.
As per my observation, the inbuilt plugins are working fine but when using other plugin like mysql or asterisk it gives error. Please suggest.
Again reinstalled nagios plugin, now getting below error for check_mysql
(Return code of 127 is out of bounds - plugin may be missing)
Please suggest a resolution
