Hi ,
I have installed nagios core 4x on suse 11 linux sever using quick installation guide .
We have all test cases in java to test features of remote linux servers.
so i would like to add java plugin to nagios to reuse exiting java testcases.
can we add java plugin to nagios core , if so please share me some examples.
BR// venkatesh
Add java plugin to nagios 4x on SUSE 11 linux server
venkatesh ch
Re: Add java plugin to nagios 4x on SUSE 11 linux server
If you have a standalone .jar file you can create a new command with a command_line like "java -jar <filename>" that will run your custom Java plugin. Just make sure the plugin reports in the proper Nagios format as explained in our documentation:
https://nagios-plugins.org/doc/guidelines.html
