It seems my check_log will not 'RECOVER' after sending out the alert for the log query after a match of the string is found. Please see below:
host_name ahostname
service_description LOGIN FAILURE
check_command check_nrpe!check_ftplog
max_check_attempts 1
is_volatile 1
command[check_ftplog]=/usr/local/nagios/libexec/check_log -F /var/log/vsftpd.log -O /tmp/tmplog.log -q incorrect
***** Nagios *****
Notification Type: PROBLEM
Service: LOGIN FAILURE
Host: ahostnamehere
Address: x.x.x.x
State: CRITICAL
Date/Time: Mon Jul 21 14:06:38 EDT 2014
Additional Info:
(1) Mon Jul 21 13:55:28 2014 [pid 12965] [username] FTP response: Client 127.0.0.1, 530 Login incorrect.
No recovery has been sent or appears to be sending. Is there an option I am not setting specifically for this? Thank you.
