Ping data no longer logging since moving to 2014
GldRush98
Post by GldRush98 »
We upgraded to 2014 at the beginning of June. I just found out yesterday that ping data for every server hasn't logged data since then (or at least isn't being graphed?).
Every server's performance graph looks similar. Working fine until beginning of June, then nothing.
Only ping data seems to be affected. All other performance graphs are working as they should be.
The ping services themselves appear to be working and checking as they should as far as I can tell.
Prod XI: Debian 12 - Nagios XI 2026R1.2
Dev XI: Debian 12 - Nagios XI 2026R1.2
GldRush98
Re: Ping data no longer logging since moving to 2014
Post by GldRush98 »
Nevermind! I guess I should check the FAQ's before posting.
http://support.nagios.com/wiki/index.ph ... 14_Upgrade
edit: Confirming that did fix it :ugeek:
Sorry for the unnecessary post.
