When I try to monitor guests on an ESX host, it populates the checkboxes properly, but under the “Guest Selection” tab it
simply says:
“It appears as though the VMware SDK has not yet been installed on your Nagios XI server. You must install the SDK before you are
able to use this wizard. “
I have properly set the permissions for getguests.pl
However still facing the issue.Kindly help me out.
Re: VMware SDK has not yet been installed
Have you verified you have all of the pre-requesites installed, as well as the SDK itself?:
http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
