This is VERY confusing. It looks to me like all the commands are getting defined in /etc/nagios3/conf.d/commands.cfg. Beyond the code that I've added to that file for check_disk, do I also need to add the
command[check_disk]=/usr/lib64/nagios/plugins/check_disk $ARG1$
to /etc/nagios/nrpe.cfg? That's the only instance of nrpe.cfg that I find on my Nagios server. When ever someone speaks of making changes to files, it's often not clear which side the changes need to be made on: server or monitored node.
I just realized that this (from /etc/nagios3/conf.d/services.cfg) might be part of the problem, though:
use default-service
hostgroup_name portal
service_description Disk Space
check_command check_nrpe!check_disk
I'm thinking that maybe I didn't make all of the changes that eloyd recommended in his posting. So, I've just made the following additions:
# To /etc/nagios3/conf.d/commands.cfg...
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ -a "$ARG2$"
#To /etc/nagios3/conf.d/services.cfg...
use nrpe-service
check_command check_nrpe!check_disk!-w 20% -c 10% -p /
# To /etc/nagios/nrpe.cfg...
On the Nagios server, I ran:
# service nagios3 restart; service nagios-nrpe-server restart
and on the monitored node (since it's running Amazon Linux), I ran:
# service nagios restart
The error displayed on the "Service Status" screen changed, somewhat (see attached). At least the command is now being recognized as having been defined. The last lines in /var/log/messages on the monitored node show:
Sep 5 16:50:34 ip-10-160-23-32 nrpe[11195]: Error: Request contained command arguments, but argument option is not enabled!
Sep 5 16:50:34 ip-10-160-23-32 nrpe[11195]: Client request was invalid, bailing out...
So, it looks like there's something wrong with the way I formatted one of those lines that I added. I'm gonna Google the error...
Fixing damaged and/or partial installs of Nagios
Re: Fixing damaged and/or partial installs of Nagios
TLDR. NRPE is configured as follows (paths may vary based on how it was installed. My notes below assume you installed from source):
On the Nagios server, you will update /usr/local/nagios/etc/commands.cfg to include a check_nrpe command:
You will update /usr/local/nagios/services.cfg to execute a command via the check_nrpe service check:
(Note that we use hostgroups to associate service checks, so you may need to update hostgroups to hostname)
On the CLIENT SIDE, you need to update /usr/local/nagios/etc/nrpe.cfg (or possibly /usr/local/nagios/etc/nrpe/<something.cfg> if you use includes) to include the check_disk command (using my example above):
Make sure NRPE is running or is accessible via xinetd and you're good to go.
Does that help with the overall concept of how NRPE works?
use nrpe-service
service_description Boot Partition
hostgroups private
servicegroups System,NRPE
check_command check_nrpe!check_disk!-w 20% -c 10% -p /boot
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
I believe I'm getting a clearer sense of how things work. Thanks. Working with a few more services will likely get me to where I'm good on it all.
The main problem that I'm seeing, now, is that the line in the attached screen-shot is showing for the monitored host that I'm currently focusing on. When I check the last few lines of that host's /var/log/messages, I see:
Sep 5 22:40:31 ip-10-177-5-132 nrpe[32478]: Error: Request contained command arguments, but argument option is not enabled!
Sep 5 22:40:31 ip-10-177-5-132 nrpe[32478]: Client request was invalid, bailing out...
So, it looks like there's something wrong with the way I formatted the lines in, perhaps, commands.cfg...
Server: /etc/nagios3/conf.d/commands.cfg:
Server: /etc/nagios3/conf.d/services.cfg:
use default-service
# check_command check_nrpe!check_disk
Monitored-node: /etc/nagios/nrpe.cfg:
command[check_disk]=/usr/lib64/nagios/plugins/check_disk -w 20% -c 10% -p /
use default-service
It looks like it may be possible that your NRPE server is not accepting arguments. Try re-compiling it and doing this as the first step:
./configure --enable-command-args
I'm wondering if it might be ok to simply call the command without arguments. I just added this to nrpe.cfg:
command[check_disk]=/usr/lib/nagios/plugins/check_disk /
On the problem hosts and, now, I'm seeing what's shown in the attached screen-shot. So, transform-staging is the only problem machine at this point. That VM hasn't been managed by Chef, up to now, and, consequently, its not getting certain iptables stuff needed to make basic connectivity between it and the Nagios server work. So, I should be able to take care of that pretty quickly.
I still need to sort out a problem that I'm having, though, with Chef. I've got an email out to the Support folks at opscode.com on it.
Thanks, for all of your help on this issue. I believe I'm close to having everything cleaned up.
You can certainly hard-code the disk to check, but if you need to monitor a new disk, then you need to make a new check. It's may be easier to set up the parameters capability, but of course it's entirely up to you.
Yep, as Eric said, the downside to that is you would now have to manually create separate commands for each disk check. The nice thing about arguments is that you can specify those values on the XI server on a host by host or service by service basis. Let us know how the Chef deal goes, it won't be hard to push out new configs to change that once it's back up and running properly.
