Nagios 2014R1.2
RHEL 6.5 64 Bit
Can you please advice how to change the legend of the graph to actual date instead of week n?
How to change chart legend
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
RHEL 6 & 7
Re: How to change chart legend
What do you have your graphs filtered for? Time-wise? And what page were you viewing this from? You can filter them further, and even interact with them through Home > Graph Explorer. You can also enable the highcharts graphs and use them instead of PNP through Admin > Manage System Config.
Filter set to Last Month. Week n legend is so hard to process, it would be better in Month names.slansing wrote:What do you have your graphs filtered for? Time-wise? And what page were you viewing this from? You can filter them further, and even interact with them through Home > Graph Explorer. You can also enable the highcharts graphs and use them instead of PNP through Admin > Manage System Config.
HighCharts is fine for single parameters but one you get lots of them in a monitor it is practically unusable with legends taking up all the space and all the overlapped values is a big mess. See example below. Unchecking them one by one is a big pain and they toggle back automatically (probably due to auto refresh)
The only problem with the previous graph module is the Week n based scale, so I would appreciate a solution to get rid of this.
RHEL 6 & 7
RHEL 6 & 7
Yep, I spoke with a dev about this last week and it looks like this is being resolved by re-sizing the highcharts graphs in the next (hopefully) update.
So is there any way to change the Week n scale?slansing wrote:Yep, I spoke with a dev about this last week and it looks like this is being resolved by re-sizing the highcharts graphs in the next (hopefully) update.
RHEL 6 & 7
RHEL 6 & 7
I am not sure about this one - it is is "developers question". You can post a feature request on our public tracker and follow up on it, or I can post one internally if you want me to. Thanks!So is there any way to change the Week n scale?
Please assist to post for me. Thanks.lmiltchev wrote:I am not sure about this one - it is is "developers question". You can post a feature request on our public tracker and follow up on it, or I can post one internally if you want me to. Thanks!So is there any way to change the Week n scale?
RHEL 6 & 7
RHEL 6 & 7
Done. TASK ID 3941.
