Multiple disks monitoring in one command
Justino
Post by Justino »
Hi Everyone,
I've been using Nagios for a while now, but i'm rebuilding our set-up so we can monitor everything on SNMP level.
I only have one small problem with a command.
I'm trying to get multiple disks in 1 command, but I can't get it right :s
original: $USER1$/manubulon/check_snmp_storage.pl -H ***.***.***.*** -C public -m /vmfs/volumes/****** -w 1 -c 2
i tried applying -m twice, but it only takes the last -m command on the line.
I hope someone can help me out.
Thanks in advance.
Re: Multiple disks monitoring in one command
Post by Box293 »
check_snmp_storage.pl --help
Specifically:
  example :
  Browse storage list : <script> -C <community> -H <host> -m <anything> -w 1 -c 2 -v
  the -m option allows regexp in perl format :
  Test drive C,F,G,H,I on Windows       : -m ^[CFGHI]:
  Test all mounts containing /var       : -m /var
  Test all mounts under /var            : -m ^/var
  Test only /var                        : -m /var -r
  Test all swap spaces                  : -m ^Swap
  Test all but swap spaces              : -m ^Swap -e
