I was running an older version 3.xxx version of nagios on a debian linux install. I removed it and I have installed version 4.0.8. Everything works fine except when I select map it gives me the error "/nagios/cgi-bin/statusmap.cgi was not found on this server." This is mapped to /usr/local/nagios/sbin in apache and there is no statusmap.cgi file here. If I do a find there is one located in "/usr/lib/cgi-bin/nagios3/" but this is a leftover from nagios 3. I have tried reinstalling but this doesn't resolve it and I can't see anything noticeable in the errors that tells me why this isn't installing. Does anyone have any suggestions since everything else works fine so far.
Paul
statusmap.cgi not found on server
Re: statusmap.cgi not found on server
You may be missing a requirement or two to build the cgi. Do you have a log of the configure and compile of nagios core 4?
Thanks, here it is.
[H[2J]0;root@psjlinux: /etc/nagios4root@psjlinux:/etc/nagios4# ./configure --with-command-group=nagcmd
checking for a BSD-compatible install... /usr/bin/install -c
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether make sets $(MAKE)... yes
checking for strip... /usr/bin/strip
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking whether time.h and sys/time.h may both be included... yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking grp.h usability... yes
checking grp.h presence... yes
checking for grp.h... yes
checking libgen.h usability... yes
checking libgen.h presence... yes
checking for libgen.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking pwd.h usability... yes
checking pwd.h presence... yes
checking for pwd.h... yes
checking regex.h usability... yes
checking regex.h presence... yes
checking for regex.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking socket.h usability... no
checking socket.h presence... no
checking for socket.h... no
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking for string.h... (cached) yes
checking for strings.h... (cached) yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking for sys/types.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking for sys/wait.h... (cached) yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking for sys/stat.h... (cached) yes
checking sys/timeb.h usability... yes
checking sys/timeb.h presence... yes
checking for sys/timeb.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/msg.h usability... yes
checking sys/msg.h presence... yes
checking for sys/msg.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking uio.h usability... no
checking uio.h presence... no
checking for uio.h... no
checking for unistd.h... (cached) yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking wchar.h usability... yes
checking wchar.h presence... yes
checking for wchar.h... yes
checking for an ANSI C-conforming const... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for struct tm.tm_zone... yes
checking for mode_t... yes
checking for pid_t... yes
checking for size_t... yes
checking return type of signal handlers... void
checking for uid_t in sys/types.h... yes
checking type of array argument to getgroups... gid_t
checking for va_copy... yes
checking for vsnprintf... yes
checking for snprintf... yes
checking for asprintf... yes
checking for vasprintf... yes
checking for C99 vsnprintf... yes
checking for library containing getservbyname... none required
checking for library containing connect... none required
checking for initgroups... yes
checking for setenv... yes
checking for strdup... yes
checking for strstr... yes
checking for strtoul... yes
checking for unsetenv... yes
checking for type of socket size... size_t
checking for library containing nanosleep... none required
checking for mail... /usr/bin/mail
checking for glibc at least version 2.4... yes
checking sys/epoll.h usability... yes
checking sys/epoll.h presence... yes
checking for sys/epoll.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking for main in -liconv... no
checking for gdImagePng in -lgd (order 1)... no
checking for gdImagePng in -lgd (order 2)... no
checking for gdImagePng in -lgd (order 3)... no
checking for gdImagePng in -lgd (order 4)... no
*** GD, PNG, and/or JPEG libraries could not be located... *********
Boutell's GD library is required to compile the statusmap, trends
and histogram CGIs. Get it from http://www.boutell.com/gd/, compile
it, and use the --with-gd-lib and --with-gd-inc arguments to specify
the locations of the GD library and include files.
NOTE: In addition to the gd-devel library, you'll also need to make
sure you have the png-devel and jpeg-devel libraries installed
on your system.
NOTE: After you install the necessary libraries on your system:
1. Make sure /etc/ld.so.conf has an entry for the directory in
which the GD, PNG, and JPEG libraries are installed.
2. Run 'ldconfig' to update the run-time linker options.
3. Run 'make clean' in the Nagios distribution to clean out
any old references to your previous compile.
4. Rerun the configure script.
NOTE: If you can't get the configure script to recognize the GD libs
on your system, get over it and move on to other things. The
CGIs that use the GD libs are just a small part of the entire
Nagios package. Get everything else working first and then
revisit the problem. Make sure to check the nagios-users
mailing list archives for possible solutions to GD library
problems when you resume your troubleshooting.
checking ltdl.h usability... no
checking ltdl.h presence... no
checking for ltdl.h... no
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for dlopen in -ldl... yes
checking for extra flags needed to export symbols... -Wl,-export-dynamic
checking for linker flags for loadable modules... -shared
checking for traceroute... /usr/sbin/traceroute
checking for type va_list... yes
checking for perl... /usr/bin/perl
configure: creating ./config.status
config.status: creating Makefile
config.status: creating lib/Makefile
config.status: creating subst
config.status: creating pkginfo
config.status: creating base/Makefile
config.status: creating common/Makefile
config.status: creating contrib/Makefile
config.status: creating cgi/Makefile
config.status: creating html/Makefile
config.status: creating module/Makefile
config.status: creating worker/Makefile
config.status: creating worker/ping/Makefile
config.status: creating xdata/Makefile
config.status: creating daemon-init
config.status: creating t/Makefile
config.status: creating t-tap/Makefile
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: creating lib/snprintf.h
config.status: lib/snprintf.h is unchanged
config.status: creating lib/iobroker.h
config.status: lib/iobroker.h is unchanged
Creating sample config files in sample-config/ ...
*** Configuration summary for nagios 4.0.8 08-12-2014 ***:
General Options:
Nagios executable: nagios
Nagios user/group: nagios,nagios
Command user/group: nagios,nagcmd
Event Broker: yes
Install ${prefix}: /usr/local/nagios
Install ${includedir}: /usr/local/nagios/include/nagios
Lock file: ${prefix}/var/nagios.lock
Check result directory: ${prefix}/var/spool/checkresults
Init directory: /etc/init.d
Apache conf.d directory: /etc/apache2/conf.d
Mail program: /usr/bin/mail
Host OS: linux-gnu
IOBroker Method: epoll
Web Interface Options:
HTML URL: http://localhost/nagios/
CGI URL: http://localhost/nagios/cgi-bin/
Traceroute (used by WAP): /usr/sbin/traceroute
Review the options above for accuracy. If they look okay,
type 'make all' to compile the main program and CGIs.
]0;root@psjlinux: /etc/nagios4root@psjlinux:/etc/nagios4# make all
cd ./base && make
make[1]: Entering directory `/etc/nagios4/base'
make -C ../lib
make[2]: Entering directory `/etc/nagios4/lib'
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c squeue.c -o squeue.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c kvvec.c -o kvvec.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c iocache.c -o iocache.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c iobroker.c -o iobroker.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c bitmap.c -o bitmap.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c dkhash.c -o dkhash.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c runcmd.c -o runcmd.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c nsutils.c -o nsutils.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c fanout.c -o fanout.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c pqueue.c -o pqueue.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c worker.c -o worker.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c skiplist.c -o skiplist.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c nsock.c -o nsock.o
gcc -Wall -g -O2 -DHAVE_CONFIG_H -c nspath.c -o nspath.o
ar cr libnagios.a squeue.o kvvec.o iocache.o iobroker.o bitmap.o dkhash.o runcmd.o nsutils.o fanout.o pqueue.o worker.o skiplist.o nsock.o nspath.o
make[2]: Leaving directory `/etc/nagios4/lib'
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCORE -o nagios nagios.o broker.o nebmods.o ../common/shared.o nerd.o query-handler.o workers.o checks.o config.o commands.o events.o flapping.o logging.o macros-base.o netutils.o notifications.o sehandlers.o utils.o retention-base.o xretention-base.o comments-base.o xcomments-base.o objects-base.o xobjects-base.o statusdata-base.o xstatusdata-base.o perfdata-base.o xperfdata-base.o downtime-base.o -Wl,-export-dynamic -lm -ldl ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCORE -o nagiostats nagiostats.c -lm ../lib/libnagios.a
make[1]: Leaving directory `/etc/nagios4/base'
cd ./cgi && make
make[1]: Entering directory `/etc/nagios4/cgi'
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -DJSON_NAGIOS_4X -o archivejson.cgi archivejson.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a archiveutils.o jsonutils.o
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o avail.cgi avail.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o cmd.cgi cmd.c extcmd_list.o ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o config.cgi config.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o extinfo.cgi extinfo.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o history.cgi history.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o notifications.cgi notifications.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -DJSON_NAGIOS_4X -o objectjson.cgi objectjson.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a jsonutils.o
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o outages.cgi outages.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o showlog.cgi showlog.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o status.cgi status.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -DJSON_NAGIOS_4X -o statusjson.cgi statusjson.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a jsonutils.o
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o statuswml.cgi statuswml.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o summary.cgi summary.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o tac.cgi tac.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a
gcc -Wall -I.. -g -O2 -DHAVE_CONFIG_H -DNSCGI -o statuswrl.cgi statuswrl.c ../common/shared.o getcgi.o cgiutils.o cgiauth.o macros-cgi.o objects-cgi.o xobjects-cgi.o statusdata-cgi.o xstatusdata-cgi.o comments-cgi.o downtime-cgi.o ../lib/libnagios.a -lm
make[1]: Leaving directory `/etc/nagios4/cgi'
cd ./html && make
make[1]: Entering directory `/etc/nagios4/html'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/etc/nagios4/html'
if [ xyes = xyes ]; then \
cd ./module && make; \
fi
make[1]: Entering directory `/etc/nagios4/module'
make[1]: Leaving directory `/etc/nagios4/module'
cd ./worker && make all
make[1]: Entering directory `/etc/nagios4/worker'
cd ./ping && make all
make[2]: Entering directory `/etc/nagios4/worker/ping'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/etc/nagios4/worker/ping'
make[1]: Leaving directory `/etc/nagios4/worker'
*** Compile finished ***
If the main program and CGIs compiled without any errors, you
can continue with installing Nagios as follows (type 'make'
without any arguments for a list of all possible options):
make install
- This installs the main program, CGIs, and HTML files
make install-init
- This installs the init script in /etc/init.d
make install-commandmode
- This installs and configures permissions on the
directory for holding the external command file
make install-config
- This installs *SAMPLE* config files in /usr/local/nagios/etc
You'll have to modify these sample files before you can
use Nagios. Read the HTML documentation for more info
on doing this. Pay particular attention to the docs on
object configuration files, as they determine what/how
things get monitored!
make install-webconf
- This installs the Apache config file for the Nagios
web interface
make install-exfoliation
- This installs the Exfoliation theme for the Nagios
web interface
make install-classicui
- This installs the classic theme for the Nagios
web interface
*** Support Notes *******************************************
If you have questions about configuring or running Nagios,
please make sure that you:
- Look at the sample config files
- Read the documentation on the Nagios Library at:
http://library.nagios.com
before you post a question to one of the mailing lists.
Also make sure to include pertinent information that could
help others help you. This might include:
- What version of Nagios you are using
- What version of the plugins you are using
- Relevant snippets from your config files
- Relevant error messages from the Nagios log file
For more information on obtaining support for Nagios, visit:
http://support.nagios.com
Enjoy.
cd ./base && make
make -C ../lib
cd ./cgi && make
cd ./html && make
fi
make install
make install-init
make install-config
web interface
web interface
web interface
Enjoy.
]0;root@psjlinux: /etc/nagios4root@psjlinux:/etc/nagios4# make install
cd ./base && make install
make install-basic
make[2]: Entering directory `/etc/nagios4/base'
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/bin
/usr/bin/install -c -m 774 -o nagios -g nagios nagios /usr/local/nagios/bin
/usr/bin/install -c -m 774 -o nagios -g nagios nagiostats /usr/local/nagios/bin
make[2]: Leaving directory `/etc/nagios4/base'
make strip-post-install
/usr/bin/strip /usr/local/nagios/bin/nagios
/usr/bin/strip /usr/local/nagios/bin/nagiostats
cd ./cgi && make install
make install-basic
make[2]: Entering directory `/etc/nagios4/cgi'
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/sbin
for file in *.cgi; do \
/usr/bin/install -c -m 775 -o nagios -g nagios $file /usr/local/nagios/sbin; \
done
make[2]: Leaving directory `/etc/nagios4/cgi'
/usr/bin/strip /usr/local/nagios/sbin/$file; \
done
cd ./html && make install
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/media
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/stylesheets
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/contexthelp
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/docs
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/docs/images
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/js
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/images
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/images/logos
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/includes
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/includes/rss
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/includes/rss/extlib
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/share/ssi
/usr/bin/install -c -m 664 -o nagios -g nagios robots.txt /usr/local/nagios/share
rm -f /usr/local/nagios/share/index.html
rm -f /usr/local/nagios/share/main.html
rm -f /usr/local/nagios/share/side.html
/usr/bin/install -c -m 664 -o nagios -g nagios jsonquery.html /usr/local/nagios/share
/usr/bin/install -c -m 664 -o nagios -g nagios rss-corefeed.html /usr/local/nagios/share
/usr/bin/install -c -m 664 -o nagios -g nagios rss-newsfeed.html /usr/local/nagios/share
for file in *.php; \
do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share; done
for file in stylesheets/*.css; \
do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/stylesheets; done
for file in contexthelp/*.html; \
do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/contexthelp; done
for file in js/*.js; \
do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/js; done
for file in images/*.gif; \
do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/images; done
for file in images/*.jpg; \
for file in images/*.png; \
for file in images/*.ico; \
for file in images/logos/*.*; \
do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/images/logos; done
for file in includes/*.*; \
do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/includes; done
for file in includes/rss/*.*; \
do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/includes/rss; done
for file in includes/rss/extlib/*.*; \
do /usr/bin/install -c -m 664 -o nagios -g nagios $file /usr/local/nagios/share/includes/rss/extlib; done
make[1]: Entering directory `/etc/nagios4'
cp -rf contrib/exfoliation/stylesheets/* /usr/local/nagios/share/stylesheets
cp -rf contrib/exfoliation/images/* /usr/local/nagios/share/images
*** Exfoliation theme installed ***
NOTE: Use 'make install-classicui' to revert to classic Nagios theme
make[1]: Leaving directory `/etc/nagios4'
make install-basic
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/var/archives
/usr/bin/install -c -m 775 -o nagios -g nagcmd -d /usr/local/nagios/var/spool/checkresults
chmod g+s /usr/local/nagios/var/spool/checkresults
*** Main program, CGIs and HTML files installed ***
You can continue with installing Nagios as follows (type 'make'
make install-init
make install-config
- This installs sample config files in /usr/local/nagios/etc
]0;root@psjlinux: /etc/nagios4root@psjlinux:/etc/nagios4# make install-init
/usr/bin/install -c -m 755 -d -o root -g root /etc/init.d
/usr/bin/install -c -m 755 -o root -g root daemon-init /etc/init.d/nagios
*** Init script installed ***
]0;root@psjlinux: /etc/nagios4root@psjlinux:/etc/nagios4# make install-config
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/etc
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/etc/objects
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/nagios.cfg /usr/local/nagios/etc/nagios.cfg
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/cgi.cfg /usr/local/nagios/etc/cgi.cfg
/usr/bin/install -c -b -m 660 -o nagios -g nagios sample-config/resource.cfg /usr/local/nagios/etc/resource.cfg
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/template-object/templates.cfg /usr/local/nagios/etc/objects/templates.cfg
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/template-object/commands.cfg /usr/local/nagios/etc/objects/commands.cfg
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/template-object/contacts.cfg /usr/local/nagios/etc/objects/contacts.cfg
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/template-object/timeperiods.cfg /usr/local/nagios/etc/objects/timeperiods.cfg
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/template-object/localhost.cfg /usr/local/nagios/etc/objects/localhost.cfg
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/template-object/windows.cfg /usr/local/nagios/etc/objects/windows.cfg
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/template-object/printer.cfg /usr/local/nagios/etc/objects/printer.cfg
/usr/bin/install -c -b -m 664 -o nagios -g nagios sample-config/template-object/switch.cfg /usr/local/nagios/etc/objects/switch.cfg
*** Config files installed ***
Remember, these are *SAMPLE* config files. You'll need to read
the documentation for more information on how to actually define
services, hosts, etc. to fit your particular needs.
]0;root@psjlinux: /etc/nagios4root@psjlinux:/etc/nagios4# make install-commandmode
/usr/bin/install -c -m 775 -o nagios -g nagcmd -d /usr/local/nagios/var/rw
chmod g+s /usr/local/nagios/var/rw
*** External command directory configured ***
]0;root@psjlinux: /etc/nagios4root@psjlinux:/etc/nagios4# exit
exit
Script done on Mon 29 Sep 2014 10:16:08 AM PDTRe: statusmap.cgi not found on server
A quote from your ./configure log:
You need too install a few packages: gd, gd-devel, png-devel, jpeg-devel and then try again.** GD, PNG, and/or JPEG libraries could not be located... *********
on your system.
