Export current perfdata to csv/excel
BanditBBS
Post by BanditBBS »
Any method to export current perf data into a spreadsheet?
For example, one of my disk checks is replyign with this:
DISK WARNING - free space: /ut1002 98 GB (17% inode=17%); /un1001 18 GB (18% inode=18%); /un1002 17 GB (17% inode=17%);| /=1GB;0;0;0;1 /tmp=1GB;7;8;0;9 /usr=5GB;11;12;0;14 /var=8GB;11;12;0;14 /boot=0GB;0;0;0;0 /dev/shm=0GB;49;55;0;62 /interface=60GB;76;86;0;96 /ua1002=90GB;96;108;0;120 /ua1001=62GB;88;99;0;110 /backupnew=0GB;1167;1313;0;1459 /us1001=38GB;39;44;0;49 /ur1001=218GB;560;630;0;700 /ut1002=451GB;440;495;0;550 /un1001=81GB;79;89;0;99 /un1002=82GB;79;89;0;99 /uc1001=0GB;3;3;0;4 /uf1001=316GB;800;900;0;1000 /ud1007=672GB;720;810;0;900 /ud1008=590GB;720;810;0;900 /ud1010=325GB;720;810;0;900 /ud1011=610GB;720;810;0;900 /ud1012=515GB;720;810;0;900 /backup=0GB;629;708;0;787
We'd like to get all that data into a spreadsheet so we can play with the numbers, any method to do that?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
abrist
Red Shirt
Re: Export current perfdata to csv/excel
Post by abrist »
Echoing that string through a a series of seds would give you a csv:
echo "<string>" | sed 's/.*|//g' | sed 's/ /\n/g' | sed 's/=/,/g' | sed 's/;/,/g'
Outputs:
/,1GB,0,0,0,1
/tmp,1GB,7,8,0,9
/usr,5GB,11,12,0,14
/var,8GB,11,12,0,14
/boot,0GB,0,0,0,0
/dev/shm,0GB,49,55,0,62
/interface,60GB,76,86,0,96
/ua1002,90GB,96,108,0,120
/ua1001,62GB,88,99,0,110
/backupnew,0GB,1167,1313,0,1459
/us1001,38GB,39,44,0,49
/ur1001,218GB,560,630,0,700
/ut1002,451GB,440,495,0,550
/un1001,81GB,79,89,0,99
/un1002,82GB,79,89,0,99
/uc1001,0GB,3,3,0,4
/uf1001,316GB,800,900,0,1000
/ud1007,672GB,720,810,0,900
/ud1008,590GB,720,810,0,900
/ud1010,325GB,720,810,0,900
/ud1011,610GB,720,810,0,900
/ud1012,515GB,720,810,0,900
/backup,0GB,629,708,0,787
But I would presume you are looking for a solution in the ui. I wonder if the actions component could do this.
Post by Box293 »
Have a look at my performance data tool, it displays the data from RRDs into a table.
http://exchange.nagios.org/directory/Ad ... ol/details
BanditBBS
Post by BanditBBS »
Andy,
Is there a variable I can use inthe actions component to use the most recent perfdata?
Box,
I like that, definitely keeping it installed, but won't work for this project.
abrist
Red Shirt
Post by abrist »
BanditBBS wrote:Is there a variable I can use in the actions component to use the most recent perfdata?
Yep. For hosts: %hostperfdata%
Services: %serviceperfdata%
So you could pass these to a script and then run the seds on the string and then do whatever you want with the string.
Check out the actions component documentation:
http://assets.nagios.com/downloads/nagi ... ponent.pdf
BanditBBS
Post by BanditBBS »
Prepare for ugliness beyond comparison...
You have been warned...
#! /bin/bash
cd /app01/perfdata
mkdir /tmp/disk
ls -ldm1 $1* >> /tmp/disk/folders.txt
while read line
do
        if [ -f /app01/perfdata/$line/Check_Disk.xml ]; then
                temp=$(cat /app01/perfdata/$line/Check_Disk.xml |grep NAGIOS_PERFDATA)
                temp2=",$line"
                echo "$temp" | sed 's/<NAGIOS_PERFDATA>//g' | sed 's/<\/NAGIOS_PERFDATA>//g' |sed "s/ /$temp2\n/g" | sed 's/=/,/g' | sed 's/GB;/,/g' | sed 's/MB;/,/g' | sed 's/;/,/g' >> /tmp/test.csv
        fi
done < /tmp/disk/folders.txt
rm -rf /tmp/disk
That does what I want, the reason for MB and GB removal is one XI box is charting as MB and the other is charting as GB, otherwise if it was mixed I'd keep it. Also, the 1 command line argument I supply is the 3-4 letter code for the customer I want to see the data for.
Close this up, I just posted in case anyone else wants something similar.
