En NNA 2014R1.9 the Dashboard in the Summary per Source dont have Top 5 Talkers by Ports...
Can you help me ?
Regards!
SD
NNA Sumary Source dont Top 5 Talker by Port
Re: NNA Sumary Source dont Top 5 Talker by Port
You can click on the source, then go to the "Queries" tab to run a query. You can enter:
Aggregate By: srcport,dstport
Time Frame: <select a time period>
and click on "Run Query".
You will be able to see the source and destination ports on the page. You can also sort the data by clicking on each (well, most) columns.
http://assets.nagios.com/downloads/nagi ... alyzer.pdf
Hi!
Doing that, im able to see the top 5 talkers ports in the Summary Page ?
Regards!
Regards!
I run the query...but in the Summary still duplicating the top 5 talkers by IP...no Summary 5 Top Talkers by Port....
Regards!
SD
Regards!
SD
It seems like this is a bug. The "Top 5 Talkers" under the "Summary" tab don't show the accurate into. On the other hand, if you to to the "Reports" tab, and select "Top 5 Talkers By Source/Destination Port", the correct info is displayed.
I already filed an internal bug report (TASK ID 4054). I expect this to be fixed in the next release of Nagios Network Analyzer. Thanks for bringing our attention to this!
Hello oslec,
This has been fixed in our repository - it will be included in the next release. For the time being if you'd like to apply a fix you can follow these directions:
1. Download the attached summary.zip file and extract it
2. Move the extracted summary.js file to /var/www/html/nagiosna/www/media/js and overwrite your current file
