check_mysql_all
rquaresma
check_mysql_all
Post by rquaresma »
Hello!
i had downloaded this pluguin and i am using this by this way :
./check_mysql_all -K mysql_query -H 187.1.133.25 -u webmr -p webMR123Branc0 -d webmr -a'query=SELECT * FROM pf_carga WHERE status IN ("falha")'
CRITICAL: 0 records returned
anyone knows how can i use by the way bellow:
./check_mysql_all -K mysql_query -H 187.1.133.25 -u webmr -p webMR123Branc0 -d webmr -a 'SELECT * ,IF(TIMESTAMPDIFF(SECOND, dt_alteracao, NOW()) <'25200', '0', '1') FROM ve_carga_status WHERE ds_tabela = 'SZO010''
CRITICAL: No Query Provided
thanks
Re: check_mysql_all
Post by Box293 »
It looks like you are missing query=
rquaresma
Re: check_mysql_all
Post by rquaresma »
Box293 wrote:It looks like you are missing query=
Hi Box293,
Do you know anyway to correct it?
Re: check_mysql_all
You just forgot to type it when typing out the command:
./check_mysql_all -K mysql_query -H 187.1.133.25 -u webmr -p webMR123Branc0 -d webmr -a 'query=SELECT * ,IF(TIMESTAMPDIFF(SECOND, dt_alteracao, NOW()) <'25200', '0', '1') FROM ve_carga_status WHERE ds_tabela = 'SZO010''
