I didn't do that.
If I do that will it override any other notifications sent to contacts when issues occur ?
Setting downtime in nagios
Re: Setting downtime in nagios
It will if that is what you tell it to do. You can have more than one recipient of notifications. Review this: http://nagios.sourceforge.net/docs/nagi ... tions.html for more information.
Ok that worked ...
Will do some more testing and make sure it works as we want ...
Ok tested and all working.
I wrote a python script instead, but does what I need. It disables all checks on both the host and its services when the downtime starts and then enables them all back up again with the downtime ends.
Thanks for your help
Glad to help. Good luck!
Yes. You can close it.
Thanks.
Thanks.
