TOP 5 talkers in NNA
rashid2014
Post by rashid2014 »
hello !
please i want some explanation about top 5 talker.
my source have 192.168.0.178 ip address and the list of top 5 talkers is
sreinhardt
-fno-stack-protector
Re: TOP 5 talkers in NNA
Post by sreinhardt »
We tried to make them pretty self explainitory, let's see if I can give a bit more detail
By destination IP: looks at where the traffic was being sent to, results are ordered by IP that received the most traffic.
By source IP: Same as destination, but reversed. Results are ordered by who sent the most traffic.
By destination port: Again same as above, but look at all IPs and order by overall most traffic to each receiving port.
By source port: Again same as above, but look at all IPs and order by overall most traffic to each sending port
Actually this is a bug
This has been fixed in our repository - it will be included in the next release. For the time being if you'd like to apply a fix you can follow these directions:
1. Download the attached summary.zip file and extract it
2. Move the extracted summary.js file to /var/www/html/nagiosna/www/media/js and overwrite your current file
rashid2014
hello!
please i don't understand wath ist actully a bug?thanks
rashid2014
hello
i do what you say but i don't see any change.
Clear the browsers cache and reload the page. Let me know if this fixed your issue.
BTW, I just tested the patch and it worked for me just fine (my top 5 talkers don't show the same info in all sections like they used to).
rashid2014
hello
i clear the browser cache and reload but nothing change...the sections are the same.
Did you actually follow scottwilkerson's instructions?
Run the following command from the CLI on the Nagios NA server and show us the output:
ll /var/www/html/nagiosna/www/media/js/summary.js
eloyd
Cool Title Here
Post by eloyd »
Here are the steps I took to fix this bug. All of this was performed on the machine running Nagios Network Analyzer:
cd /tmp
wget -O summary.zip http://support.nagios.com/forum/download/file.php?id=6531
unzip summary.zip
cp summary.js /var/www/html/nagiosna/www/media/js
Then you go to your browser and reload the page with the summary report. If it fails to change, you need to force a reload that ignores browser cache. On Firefox, this is Control-Shift-R. On Explorer it is Shift-F5. If that doesn't work for you, you will need to figure out how to clear your browser cache and reload the page.
rashid2014, were you able to resolve your issue? Any updates?
