Hi all,
I am getting this error for check_windows_update.ps1 ,but after some time this error will go automatically :
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages
Can some one guide me how to remove this error. do i have to change the time settings for the command to work?
[HELP] How to fix :Received 0 bytes from daemon
sh.shekhar89
Re: [HELP] How to fix :Received 0 bytes from daemon
Hi
do you see something in you nrpe log? maybe there is the answer of you problem. I got something similar, but the log says "Error: Request contained command arguments!" and to repair this I have to do,
recompile the nrpe agent, like this:
./configure --enable-command-args
make all
make install-plugin
make install-daemon
make install-daemon-config
make install-xinetd
I have done everything, but now when i just run "make all" I got other error. But this is the way that you can fix the error.
Best Regards!
Hope you can repair that!
make all
make install-plugin
make install-daemon
make install-xinetd
Best Regards!
Checking the remote nrpe logs (usually system messages) will help identify why you are having this issue.
Also, the following doc may be useful to you:
http://assets.nagios.com/downloads/nagi ... utions.pdf
