Nagios Core - removing hosts
peterepka
Post by peterepka »
Hi
I'm very new to Nagios.
I need some help removing hosts.
We have both Nagios Core and Nagios CCM. I can remove/add hosts and services through the web interface for Nagios CCM succesfully.
However I need to remove a couple of hosts from Nagios Core.
Can this only be done via the CLI ?
If so, which directory on the server do i go to. Do i just remove the .cfg files, or is there a central file that needs editing ?
Thanks loads in advance
Pete
Re: Nagios Core - removing hosts
The point of the CCM is to eliminate the need to edit files on the CLI. What specific issue are you having that would require you to remove the flat files?
peterepka
Post by peterepka »
When I remove a host from CCM, it is not removed from Nagios Core
Are you making sure to click Apply Config after removing the hosts? Is it only hosts that are sticking around or do services stay as well?
peterepka
Post by peterepka »
Hi
Yes - i've clicked Apply Configuration.
It's a strange one.
I've deleted a total of 3 hosts from NagiosCCM
When you click on "hosts" (under Current Status within Nagios Core) you can see both the host and the old service for all 3 deleted hosts.
when you click on "services" (under Current Status within Nagios Core) I can see 2 out of the 3 services
abrist
Red Shirt
Post by abrist »
Are those host and service files still persisting in your core configs?
peterepka
Post by peterepka »
Hi
which core config files do you mean ?
there are no entries for hosts/services in
/usr/local/nagios/etc/nagios.cfg
there are entries for the hosts under
/usr/local/nagios/etc/hosts
if i remove these .cfg files for the hosts that i've deleted out of CCM, what will happen ?
(ok, just test deleted one of the files. nothing has changed on Nagios Core)
Post by slansing »
The CCM should be used to remove hosts, you need to remove a host's services first, then the host, because of the database relationship. After you apply configuration, if the host is still viewable from the Host Detail / Service Detail pages, then you should check to see if the config files for that host are still present in:
/usr/local/nagios/etc/services
If they are, manually remove them there, this is known as the ghost host phenomenon that occurs when, for whatever reason, the flat config files were actually not deleted when the DB entries were. You should then be able to restart core, and see that the hosts are indeed gone. If they re-populate in those directories after another apply configuration, that means that A: They are still in the CCM, or B: For some reason, they are still in the database but not in the CCM (which to my knowledge does not cause the flat files to be re-created as that portion is later in the reconfiguration script) but it is a possibility.
peterepka
Post by peterepka »
So I've connected to the server and in both
and
there are now now traces of the files relating to the servers in question.
however they are still in Nagios Core when i look under Hosts and Services.
Any further advice would be really appreciated.
Post by slansing »
Hmm, sounds like nagios may not have restarted properly, if there are none of those config files in those directories, and your nagios.cfg does not pull configurations from another directory, try:
service nagios restart
And check to see if they are still in the web interface, also check to see if they are currently being checked.
