NLS Setup
Re: NLS Setup
I have not tested that (currently trying to find a more permanent fix to the root problem) but in theory that should work. I have offset my graphs in a similar way by saying something like "24 hours ago to 1 hour ago" and they line up.
Re: NLS Setup
Jake, one of our developers, to the rescue!
Everyone who is having this problem, please check your /etc/sysconfig/clock file. Make sure the ZONE= is set to your proper timezone. Also, check your /etc/php.ini and make sure your date.timezone setting is correct as well. Restart the httpd service for good measure and you should be good to go!
Re: NLS Setup
Perfect! This worked. It was both the timezone and php.ini. Thanks and great response!
Re: NLS Setup
Great! Is this fix working for everyone else? I'll leave this open for comments.
