Also, when you say it is blank, this makes me wonder if there happen to be any httpd errors of significance
tail -100 /var/log/httpd/error_log
[root@nagioslog1 ~]# tail -100 /var/log/httpd/error_log
[Sun Jan 04 03:50:02 2015] [notice] Digest: generating secret for digest authentication ...
[Sun Jan 04 03:50:02 2015] [notice] Digest: done
[Sun Jan 04 03:50:02 2015] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
[Mon Jan 05 08:27:35 2015] [notice] caught SIGTERM, shutting down
[Mon Jan 05 08:28:37 2015] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon Jan 05 08:28:37 2015] [notice] Digest: generating secret for digest authentication ...
[Mon Jan 05 08:28:37 2015] [notice] Digest: done
[Mon Jan 05 08:28:37 2015] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
[Tue Jan 06 11:34:02 2015] [error] [client 192.168.9.10] File does not exist: /var/www/html/apple-touch-icon-precomposed.png
[Tue Jan 06 11:34:02 2015] [error] [client 192.168.9.10] File does not exist: /var/www/html/apple-touch-icon.png
[Tue Jan 06 16:41:08 2015] [notice] caught SIGTERM, shutting down
[Tue Jan 06 16:42:12 2015] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Jan 06 16:42:12 2015] [notice] Digest: generating secret for digest authentication ...
[Tue Jan 06 16:42:12 2015] [notice] Digest: done
[Tue Jan 06 16:42:12 2015] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
[root@nagioslog2 ~]# tail -100 /var/log/httpd/error_log
[Sun Jan 04 03:18:03 2015] [notice] Digest: generating secret for digest authentication ...
[Sun Jan 04 03:18:03 2015] [notice] Digest: done
[Sun Jan 04 03:18:03 2015] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
[Mon Jan 05 08:27:55 2015] [notice] caught SIGTERM, shutting down
[Mon Jan 05 08:29:01 2015] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon Jan 05 08:29:01 2015] [notice] Digest: generating secret for digest authentication ...
[Mon Jan 05 08:29:01 2015] [notice] Digest: done
[Mon Jan 05 08:29:01 2015] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
[Tue Jan 06 16:41:17 2015] [notice] caught SIGTERM, shutting down
[root@nagioslog3 ~]# tail -100 /var/log/httpd/error_log
[Sun Jan 04 03:14:03 2015] [notice] Digest: generating secret for digest authentication ...
[Sun Jan 04 03:14:03 2015] [notice] Digest: done
[Sun Jan 04 03:14:03 2015] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
[Mon Jan 05 08:27:39 2015] [notice] caught SIGTERM, shutting down
[Mon Jan 05 08:28:24 2015] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Mon Jan 05 08:28:24 2015] [notice] Digest: generating secret for digest authentication ...
[Mon Jan 05 08:28:24 2015] [notice] Digest: done
[Mon Jan 05 08:28:25 2015] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
[Tue Jan 06 16:41:11 2015] [notice] caught SIGTERM, shutting down
[Tue Jan 06 16:42:00 2015] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Tue Jan 06 16:42:00 2015] [notice] Digest: generating secret for digest authentication ...
[Tue Jan 06 16:42:00 2015] [notice] Digest: done
[Tue Jan 06 16:42:00 2015] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 configured -- resuming normal operations
No question is sillytmcdonald wrote:Maybe this is a silly question, but do you have any filters applied underneath the query search bar?
I would like, butsreinhardt wrote:I'd also like to have you apply the fix here: viewtopic.php?f=38&t=30778&p=122093&hilit=+log+server#p122363
You may not be seeing crashes, but it seems to be similar issues.
You are not authorised to read this forum.
Ok thank you, If you want any information yet, do not hesitate to ask.Nagios Support wrote:Thanks, chris_Espoir! We will do some digging into this and get back to you within the next 24 hours.
Use the attached zip file:Looks like you're hitting this guy: https://github.com/elasticsearch/logstash/issues/1604, you should be able to follow the patch here: https://github.com/jordansissel/ruby-ft ... 59eccc18a3. Try replacing theses files with the ones attached to this post:
/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/ftw-0.0.39/lib/ftw/connection.rb
/usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/ftw-0.0.39/lib/ftw/pool.rb
