Getting recovery emails ONLY
brianp89
Post by brianp89 »
I have a service check that looks for a file at all times of the day. The user being notified only wants alerts to be sent when the file appears in the directory. I do NOT want any critical or warning notifications to be sent. I only want the OK (recovery) emails to be sent.
I tried unchecking all the Notification options except for "r" (recovery) but it will not send any emails unless I also check "c" (critical). Is there a way to make it ONLY send recovery emails?
To make it more clear, here is the exact process of what should happen:
Nagios checks for file, none found (critical), NO alert
Nagios checks for file, file is found (recovered), send OK alert
User sees OK alert and processes file, emptying the directory
repeat
Thank you
brianp89
Re: Getting recovery emails ONLY
Post by brianp89 »
After reading around and looking at plugins, I stumbled upon the "Negate" plugin. I have since reversed the Critical and OK return codes and it seems to have solved my issue. For reference in case anyone else has this issue, check out:
http://assets.nagios.com/downloads/nagi ... ios-XI.pdf
Sometimes simply typing it out on here helps me organize my thoughts better :)
Thanks again guys
