How to Configure Email Notification, notifications missing
swapnil.kadam
Hello Team,
Can you help me to configure email alert notification in Nagios XI, I already have a SMTP server up and running in my environment and I want to use the same for Nagios Alert Notifications.
I have attached current configuration screen shots for your reference.
Do let me know what is that I am missing to configure.
Regards,
Swapnil
Regards,
Swapnil
Re: How to Configure Email Notification, notifications missi
Make sure that the contacts you have set up also have associated XI users, and that they are using the xi_host_notification_command xi_host_notification_handler and xi_service_notification_command xi_service_notification_handler set instead of the notify-host-by-email and notify-service-by-email command set.
http://assets.nagios.com/downloads/nagi ... ntacts.pdf
Edit: I typed "command" instead of "handler"
swapnil.kadam
I cannot find xi_host_notification_command and xi_service_notification_command while setting up a contact, please find attached screen shot.
As is shown in the document provided, the commands you are looking for end in handler, which are in that list.
swapnil.kadam
Still no luck with email notifications, how can I troubleshoot what is causing the problem.
I am not getting any email after clicking on send test email in Nagios XI
Do you have an associated XI user for each contact that you are trying to send emails to?
swapnil.kadam
Please find attached screen shots for users and contacts, do let me know if anything is missing.
Can you run the following after hitting the test mail settings button
tail -50 /usr/local/nagiosxi/tmp/phpmailer.log-
swapnil.kadam
[root@ip-x-x-x-x ec2-user]# tail -50 /usr/local/nagiosxi/tmp/phpmailer.log
SMTP Error: Could not connect to SMTP host. (method=smtp;host=x.x.x.x;port=25;smtpauth=true;security=ssl)
However I have checked that I can telnet the SMTP Host from the same Nagios XI Server
[root@ip-x-x-x-x ec2-user]# telnet x.x.x.x 25
Trying x.x.x.x...
Connected to x.x.x.x.
Escape character is '^]'.
220 xxxxxxxxxxx.Domain.local Microsoft ESMTP MAIL Service, Version: 7.5.7601.17514 ready at Tue, 10 Feb 2015 19:11:46 +0000
What could be the possible reason for not getting the alert notification emails through the Nagios XI
Trying x.x.x.x...
swapnil.kadam
I have tested that I can send emails through command line, however no notifications are going through Nagios XI
[ec2-user@ip-x-x-x-x ~]$ mail -s "Hello Nagios Team" [email protected]
Hello Nagios Team
Please help to fix this issue with notifications
EOT
-----Original Message-----
Sent: Tuesday, February 10, 2015 2:52 PM
To: Kadam, Swapnil
Subject: Hello Nagios Team
Hello Nagios Team
Hello Nagios Team
EOT
To: Kadam, Swapnil
Hello Nagios Team
