Guys,
We have problems with graphs from the check_mssql_server.py script.
The perfdata.log file has the following message:
2015-02-09 16:27:33 [5248] [1] Found Performance Data for XXXXXXX / MSSQL_Lock_Wait_Times (lockwait=77175.0ms;;;;;)
2015-02-09 16:27:33 [5248] [1] Invalid Perfdata detected
When testing from the command line we have:
./check_mssql_server.py -H vsmurprdsql01 -U 'XXXXX' -P 'XXXXXX' -p 1433 --lockwait
OK: Lock Wait Average Time (ms) is 696292.0ms|lockwait=696292.0ms;;;;;
Could it be that the quotation marks are not supplied by the check_mssql_server.py script in the performance part of the output?
All other graphs are working fine, only the graph generated by check_mssql_server.py are not.
Our NagiosXI version is: 2014R2.4
and check_mssql_server.py time stamp is:
-rwxr-xr-x 1 nagios users 20215 Oct 3 2013 ./check_mssql_server.py
Cheers
Ivica
Graphs from check_mssql_server.py
nagiosnl_jorgen
Re: Graphs from check_mssql_server.py
Well, I found the same problem. This plugin does not meet the https://nagios-plugins.org/doc/guidelines.html Nagios Plugin Development Guidelines requirements:
The three semicolons are hardcodes so it's easy to fix.
Regards,
Jørgen van der Meulen
Solutions Consultant
http://www.nagios.nl
Please notice that - for instance -2015-01-12 14:38:26 [4226] [1] Invalid Perfdata detected
has one semicolon too much at the end. Either the trailing semicolons should be skipped or reduced to two semicolons.(database_pages=3451927.0;300;600;;;)
Regards,
This has already been filed internally and fixed. It should be included in the next release. I will be closing this topic now.
