EXTERNAL COMMANDS from Script
MartinS
Post by MartinS »
I am having problem getting EXTERNAL COMMAND to work when send the command directly to the nagios.cmd file.
When I run from a script all I get in the log file is...
From Script
[1423495647] EXTERNAL COMMAND: SCHEDULE_HOST_DOWNTIME;Laserjet-3015;1423495646;1423496246;1;0;7200,martin.stevens;test-from-script
When I work through the Web GUI, it also triggers the HOST DOWNTIME ALERT
From WebUI
[1423495661] EXTERNAL COMMAND: SCHEDULE_HOST_DOWNTIME;Laserjet-3015;1423495618;1423502818;1;0;7200;Martin Stevens(Systems Administrator);Testing
[1423495661] HOST DOWNTIME ALERT: Laserjet-3015;STARTED; Host has entered a period of scheduled downtime
Permissions wouldn't seem to be the issue, as I can insert the command.
Any ideas ?
Martin
Re: EXTERNAL COMMANDS from Script
In the external script, is "martin.stevens" a valid contact in Nagios?
Try changing it to the following and see if that works for you.
MartinS
Post by MartinS »
I've tested with both contact_name and the alias, and it doesn't seem to make any difference.
The contact name also matches the name in the passwd file.
define contact{
        contact_name            martin.stevens
        use                     generic-contact
        alias                   Martin Stevens(Systems Administrator)
        email                   [email protected]
Using this shell script
#!/bin/sh
now=`date +%s`
time=`date +%H:%M:%S`
commandfile='/var/spool/nagios/cmd/nagios.cmd'
MINUTES=10
STARTTIME=$(date +"%s")
ENDTIME=$(date +"%s" -d "$MINUTES min")
/usr/bin/printf "[%lu] SCHEDULE_HOST_DOWNTIME;Laserjet-3015;$STARTTIME;$ENDTIME;1;0;7200,Martin Stevens(Systems Administrator);Host Down at $time\n" $now > $commandfile
MartinS
Post by MartinS »
Right spotted my error can you see the , rather than the ; in the script... D'oh
Hey, it could have been worse :)
Let's close this up.
