At the moment im working with Nagios 3.2.0 and i have check_apache plugin running on several servers. But there is something weird going on, nagios is telling me that the apache is running but it is in critical state. I get this problem on the servers that are working on Ubuntu 12.04/14.04, the only server that has not got this problem are the servers that are running on Ubuntu 10.4. Personally, I think it's a bug in nagios, because on both the server running 12.04/14.04 & 10.4 are running the same plugin. Is this a common problem that an older Nagios version display Critical errors while it's running?
Alternatively if you want to have a more future-proof solution that won't require your custom script to be moved with your installation you could use official plugins. Something like this should work for you:
