need help to monitor remote server
ducle99
Post by ducle99 »
I try to monitor remote host, so I add remote host as indicated in the attached file, but it only works for current load and current users, and it fails for other services. Thanks very much for your help.
ddctst101.cfg
remote host
(5 KiB) Downloaded 591 times
nrpe.server.cfg
nrpe on nagios master
(7.8 KiB) Downloaded 599 times
nrpe.client.cfg
nrpe on remote host
(7.81 KiB) Downloaded 582 times
Re: need help to monitor remote server
Post by Box293 »
So for check_users, here is why it works:
ddctst101.cfg
check_command			check_nrpe!check_users
nrpe.client.cfg
Nagios looks at ddctst101.cfg and uses the argument "check_users" which it sends over to the client.
The client is listening and looks in it's config. It sees a command called "check_users" so it executes it and returns the result.
Now if you look at one that doesn't work:
ddctst101.cfg
        use                             generic-service         ; Name of service template to use
        host_name                       ddctst101
        service_description             Total Processes
	check_command			check_nrpe!check_procs
nrpe.client.cfg
The reason why this doesn't work is because nagios uses the argument "check_procs" which it sends over to the client.
The client is listening and looks in it's config. It doesn't have a command called "check_procs" so it fails.
However there is a command defined called "check_total_procs" and if you changed ddctst101.cfg to use "check_total_procs" instead of "check_procs", it would work.
Does that make sense?
ducle99
Post by ducle99 »
Thanks for your help. It works. However, I have another issue with check swap.
Here is content in nrpe.client.cfg
command[check_swap]=/usr/local/nagios/libexec/check_swap -H localhost -w 20 -c 10
On Nagios master dashboard, on the line Swap usage under status information: Missing Host or Password arguments.
Could you please help for this issue? I really appreciate for your help.
Can you post the service config for the service that runs check_nrpe for the swap usage? You likely are missing a -H in the check_nrpe args or you do not have a password defined.
ducle99
Post by ducle99 »
FIles attached.
swap.docx
snapshot of swap detail
(264.39 KiB) Downloaded 409 times
nrpe.client.cfg
nrpe.cfg on remote host
(8.05 KiB) Downloaded 551 times
ddctst101.cfg
remote host
(4.99 KiB) Downloaded 551 times
Post by Box293 »
ducle99 wrote:command[check_swap]=/usr/local/nagios/libexec/check_swap -H localhost -w 20 -c 10
The plugin check_swap does not use the -H argument. Change it to:
command[check_swap]=/usr/local/nagios/libexec/check_swap -w 20 -c 10
It's always best to test the command on the remote device first, it'll weed out these little problems.
ducle99
Post by ducle99 »
Yes, I have tried check_swap without -H option, but I still get the same error.
Post by Box293 »
On the remote host, show us the output of:
su nagios
I get:
SWAP OK - 100% free (1983 MB out of 1983 MB) |swap=1983MB;0;0;0;1983
ducle99
Post by ducle99 »
/usr/local/nagios/libexec/check_swap version 1.9.2 last updated 03.17.2011
* OVERVIEW *
This utility was written 10/25/2004 as a method for automating
the collection of SNMP based information, for the ultimate goal
of pushing the result to Nagios.
* USAGE *
/usr/local/nagios/libexec/check_swap ARGS
ARGS:
-v Print version and exit
-h Print this help message
-d n Turn debug on at level n (1-3)
-H SNMP (remote) host to poll
-w n Warning level (alert if free swap (MB) drops below this)
n% Warning level (alert if % of swap free drops below this)
-c n Critical level
n% Critical level
-p SNMP Community password on remote host
All options can be prefixed with a single or double "-".
All options are case sensitive and only eval the first character
(e.g. --debug is the same as --d, -d, -debug)
jdalrymple
Skynet Drone
Post by jdalrymple »
This must be a 3rd party check_swap plugin. Can you try the check_swap plugin from the official nagios plugins?
http://www.nagios.org/download/plugins
