lesnikov
Posts: 28 Joined: Sat Jan 19, 2013 10:40 pm
Post
by lesnikov » Tue Feb 17, 2015 7:30 pm
I'm using check_mrtg to get bandwidth/graphs from Cisco switch...
Result are shown in bytes (MB/s) and I would like them in bits? Is it possible?
conf:
command_name check_local_mrtg
command_line $USER1$/check_mrtg -F $ARG1$ -a $ARG2$ -w $ARG3$ -c $ARG4$ -e $ARG5$
use generic-service ; Inherit values from a template
host_name SW-10
service_description Port 25 Bandwidth Usage
check_command check_local_mrtgtraf!/var/www/mrtg/172.17.0.10_10125.log!AVG!1000000,2000000!5000000,5000000!10
regards.
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Tue Feb 17, 2015 9:47 pm
This is checking the file /var/www/mrtg/172.17.0.10_10125.log which is generated by MRTG.
Can you please post the MRTG config file for 172.17.0.10, it could be under /etc/mrtg perhaps
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
lesnikov
Post
by lesnikov » Tue Feb 17, 2015 10:39 pm
ok, i checked mrtg.cfg and there was everything in bytes. so i re run cfgmaker with bits
cfgmaker --global 'WorkDir: /var/www/mrtg' --global 'Options[_]: bits' --output /etc/mrtg/mrtg3.cfg [email protected] :::::2
indexmaker --output=/var/www/mrtg/index.html /etc/mrtg/mrtg.cfg
and then checked again with nagios and it is shown with as bytes
MRTG config (after changed to bits)
EnableIPv6: no
Options[_]: bits
Target[172.17.0.10_10102]: 10102:[email protected] :::::2
SetEnv[172.17.0.10_10102]: MRTG_INT_IP="" MRTG_INT_DESCR="GigabitEthernet1/0/2"
MaxBytes[172.17.0.10_10102]: 12500000
Title[172.17.0.10_10102]: Traffic Analysis for 10102 -- SW-10.slovenija.si
PageTop[172.17.0.10_10102]: <h1>Traffic Analysis for 10102 -- SW-10.slovenija.si</h1>
<div id="sysdetails">
<table>
<tr>
<td>System:</td>
<td>SW-10.slovenija.si in </td>
</tr>
<tr>
<td>Maintainer:</td>
<td></td>
</tr>
<tr>
<td>Description:</td>
<td>GigabitEthernet1/0/2 </td>
</tr>
<tr>
<td>ifType:</td>
<td>ethernetCsmacd (6)</td>
</tr>
<tr>
<td>ifName:</td>
<td>Gi1/0/2</td>
</tr>
<tr>
<td>Max Speed:</td>
<td>100.0 Mbits/s</td>
</tr>
</table>
</div>
Post
by Box293 » Tue Feb 17, 2015 10:56 pm
You're on the right path, thats what needed to be updated first.
Your service is using the command definition check_local_mrtgtraf , can you post the command definition here please.
Privacy Policy .
lesnikov
Post
by lesnikov » Tue Feb 17, 2015 11:01 pm
copied first one by mistake... :
command_name check_local_mrtgtraf
command_line $USER1$/check_mrtgtraf -F $ARG1$ -a $ARG2$ -w $ARG3$ -c $ARG4$ -e $ARG5$
./check_mrtgtraf --version
check_mrtgtraf v2.0.3 (nagios-plugins 2.0.3)
abrist
Red Shirt
Posts: 8334 Joined: Thu Nov 15, 2012 1:20 pm
Post
by abrist » Thu Feb 19, 2015 2:56 pm
I believe this may be a limitation of check_mrtgtraf. From it's usage:
[snip]
If either the incoming or outgoing rates exceed the <icl> or <ocl> thresholds (in
Bytes/sec ), a CRITICAL status results. If either of the rates exceed
the <iwl> or <owl> thresholds (in Bytes/sec ), a WARNING status results.
[snip]
Come to the
Dark Side .
lesnikov
Post
by lesnikov » Sun Feb 22, 2015 12:31 pm
Yeah... Will have to chose different plugin to get what I need.
jolson
Attack Rabbit
Posts: 2560 Joined: Thu Feb 12, 2015 12:40 pm
Post
by jolson » Mon Feb 23, 2015 5:00 pm
I see that your issue has been worked - I'll lock this forum post. Feel free to open another if you have additional issues. Thanks!
Best,
Jesse
Twits Blog
