Hi.-
I have a problem and not how to fix it .-
Apparently it should work:
./check_eximailqueue -w 200 -c 500
Mailqueue OK - 20 messages on queue
But with no nrpe:
/usr/local/nagios/libexec/check_nrpe -H localhost -c check_mailq
CHECK_NRPE: Socket timeout after 10 seconds.
What is the problem?
nrpe + check_mail
Re: nrpe + check_mail
Does NRPE work for other checks? Could you be a little clearer about exactly what is going on?
Check nrpe versions(client/server), they should be close if not matching. I'm assuming this happens with every check?
The NRPE works very well with the other services .-tonyyarusso wrote:Does NRPE work for other checks? Could you be a little clearer about exactly what is going on?
With alterations are produced error check_eximailqueue
Only the error occurs check_eximailqueuemmestnik wrote:Check nrpe versions(client/server), they should be close if not matching. I'm assuming this happens with every check?
You will need to more closely match the conditions you use in your testing with that of what NRPE is doing. I'd also check to see if the command behaves as a Nagios plugin, though this is not likely your problem.
Things to look for: Username/group membership. Environment variables, PATH comes to mind. Current working directory.
Hi.-
This is the error I see:
sudo(pam_unix)[25517]: authentication failure; logname= uid=0 euid=0 tty= ruser= rhost= user=nagios
With check_load works well
/usr/local/nagios/libexec/check_nrpe -H localhost -c check_load
OK - load average: 0.15, 0.09, 0.02|load1=0.150;15.000;30.000;0; load5=0.090;10.000;25.000;0; load15=0.020;5.000;20.000;0;
Hi.-
I solved the problem with the following line in /etc/sudoers:
nagios ALL=NOPASSWD:/usr/sbin/exim
Hi.-
Now I have another problem .-
I'm doing the same on another server but now it produces the following error:
Mailqueue WARNING - query returned no output!
renavas,
Could you provide details on both of these hosts? What OS/Version where did you get it, how did you get nrpe installed how did you get the Nagios plugins installed, etc, etc, etc.
We would like this information to help make out packaging of the Linux-Agent better, so please provide any notes you have on the process and pit-falls you had to go through.
Thank you.
Thank you.
