Friends,
I am using Nagios-4.0.1 Core for monitoring Network Infrastructure i.e. Routers & Switches as well as link monitoring.
Addition to this , i have configured Email Notifications for my internal team by using sendEmail-v1.56.tar.gz
Now i want to configure Hostwise email alerts i.e. If HOST A is having problem , Email Notifications will go to [email protected] & if HOST B is having problem , Email notifications will go to [email protected]
How can i configure hostwise email notifications ?
Regds,
Vijay
Email Notifications-Nagios Core-4.0.1
Re: Email Notifications-Nagios Core-4.0.1
Have you set up contacts for those email addresses? You will need to do so and then set those contacts in the host configurations.
http://www.thegeekstuff.com/2009/06/4-s ... ification/
Make sure to edit the appropriate files depending on your distribution.
vijaydonde
Thanks for the reply.
i have implemented configuration mentioned in below mail.
But am little bit confused as in have configured
command_name notify-host-by-email
command_line /usr/local/bin/sendEmail -s 192.168.0.127 -t [email protected],[email protected] , -xp $USER6$ -l /var/log/sendEmail -u "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" -m "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYP$
When i have tried to generate force alert only nagiosadmin is visible in GUI.
Please help....
Please help....
Could you clarify? Are you implying that you only see the notification sent for nagiosadmin? Or something else?vijaydonde wrote:When i have tried to generate force alert only nagiosadmin is visible in GUI.
