remove all hosts and services
nywils
Post by nywils »
How do I remove all the hosts and services? Everytime I delete a host from configure, i get the following error:
One or more errors were detected that prevent the host from being deleted.
Possible causes include...
The host is associated with other hosts, services, or objects that need to be deleted first
The host is maintained in a static or external configuration file
To resolve this issue...
Use the Nagios Core Configuration Manager to delete the host - or -
Manually delete the host definition from the appropriate external configuration file
Re: remove all hosts and services
Post by Box293 »
In CCD, delete the services for that host first and apply config, then try deleting the host.
