hey guys, I just noticed a problem after upgrading to the latest version. Warning alerts are not firing, but critical alerts are still working.
Warning Alerts not working after upgrade to latest version
Re: Warning Alerts not working after upgrade to latest versi
I tested this with the same results - I will speak with development regarding this issue and get back to you.
Thanks jolson.jolson wrote:I tested this with the same results - I will speak with development regarding this issue and get back to you.
No problem - I'll be sure to let you know when we make headway on this issue. Thanks!
This has been fixed.
To implement this fix, please download and extract the attached file.
Make a backup of the existing alert.php file:
Stop httpd:
Overwrite /var/www/html/nagioslogserver/application/models/alert.php with the new alert.php file.
Start httpd:
That should fix the issue. Let me know if this works for you.
For reference, default permissions are 644 root:root.
cp /var/www/html/nagioslogserver/application/models/alert.php /home/nagios/alert.php.oldCode: Select all
service httpd stopStart httpd:
service httpd startFor reference, default permissions are 644 root:root.
