Pass in varaible to nrpe
djs
Post by djs »
Hi all,
I am trying to pass in a variable to an nrpe agent through nagios.
I have a nagios server and have defined a global environment variable e.g
test_var=Hi
I can manually check that this varaible can be called by doing a
./check_nrpe -H 123.456.7.8 -c pass_arg -a $test_var
However when I try and pass in arguments into the command e.g
    use                        test-service
    host_name                  d3t
    service_description        Pass arg 1
    check_command              pass_arg_h!$test_var
It displpays "$" on the nagios webpage, does anybody know why this is and how variables can be passed in?
One aditional question if variables can be defined and called, is there any way to pass in a varaible that performs an action .eg
test_var=`ls -l /etc/nagios/ | wc -l`
    use                        test-service
    host_name                  d3t
    _YahooID    john32
Thanks in advance,
djs
ssax
Dreams In Code
Re: Pass in varaible to nrpe
Post by ssax »
Are you defining it in /usr/local/nagios/etc/resource.cfg?
If you are you should use:
    use                        test-service
    host_name                  d3t
    check_command              pass_arg_h!$test_var$
Instead of:
    use                        test-service
    host_name                  d3t
As far as it performing an action you would need to write a wrapper script that would perform the action that you would want to happen and then call the check command that you would want it to run.
