NagiosXI installation Error
angurisudhakar
Post by angurisudhakar »
i am getting below error.
URL: http://localhost/nagiosql/index.php
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosql/index.php --no-check-certificate --post-data 'Submit=Login&tfUsername=nagiosxi&tfPassword=n@gweb' -O nagiosql.login--2015-05-07 15:04:59-- http://localhost/nagiosql/index.php
Resolving proxy.intra.bt.com... 147.149.2.7
Connecting to proxy.intra.bt.com|147.149.2.7|:8080... connected.
Proxy request sent, awaiting response... 403 Forbidden
2015-05-07 15:04:59 ERROR 403: Forbidden.
NAGIOSQL LOGIN FAILED!
RESULT=1
INSTALLATION ERROR!
jdalrymple
Skynet Drone
Re: NagiosXI installation Error
Post by jdalrymple »
Sounds like a prerequisite failed. Can you post your install.log file?
Have you tried to re-run the installer?
angurisudhakar
Please find the attachment.
Did you set up your proxy by following the steps, outlined on our FAQ wiki page?
http://support.nagios.com/wiki/index.ph ... th_Proxies
jdalrymple
Skynet Drone
Did you have to set an environmental variable to get to the Internet on this box?
angurisudhakar
Yes.. Just i to am use export environment variable command for internet and dependent package installation .
angurisudhakar
Please suggest me ,i have all the dependent rpm packages with me
my question is
1. if i run ./fullinstall it will take the dependent package again from the net.?
or
it will install normallly..?
Sudhakar Anguri
jdalrymple
Skynet Drone
Re-running the install should work, however that proxy is going to be an issue. Is there any way you can give this box direct access to the Internet? If not we'll probably have to chat with the developers about how to get around that problem. We might have to unset those ENVs prior to some steps in the install/setup process, then reset them when done.
