We are having couple of Exinda box which is used for Optimization over the LAN & WAN network. Do, you got any tool which could help me to monitor those NE through Nagios?
http://www.exinda.com/
How to monitor Optimizer through Nagios
Regards
Sazzad
Sazzad
jdalrymple
- Skynet Drone
Re: How to monitor Optimizer through Nagios
It doesn't look great.
We don't have any exinda specific plugins on the exchange. I searched a bit to see what kind of SNMP support exinda has and it appears to be minimal. If you can get the vendor to supply you with a MIB for their SNMP agent you can see what all is monitorable. Also if there is any remote shell access (ssh or rsh) you could likely write some custom plugins - however we don't have anything for that type of device pre-built.
