This support forum board is for support questions relating to
Nagios Log Server , our solution for managing and monitoring critical log data.
ucemike
Posts: 56 Joined: Wed Nov 16, 2011 3:13 pm
Post
by ucemike » Fri May 15, 2015 2:44 pm
I've setup a ESXi device to send logs to udp 514 -> NLS. I can see data is coming in on the NLS.
19:26:00.875443 IP 198.X.X.85.33294 > 198.X.X.171.syslog: SYSLOG local4.info, length: 193
But no data shows up for that ip in searches. Far as I can tell the time is correct (using ntp to maintain it) and the timezone appears to be UTC.
ucemike
Post
by ucemike » Mon May 18, 2015 10:52 am
Oh, my mistake, I didn't realize 514 UDP was privileged. I had it in my head tcp was but udp wasn't for some reason.
I would just use port 9001 like I did with my other devices but vmware hypervisor firewall configuration for custom ports is ridiculously silly.
ucemike on Mon May 18, 2015 12:02 pm, edited 1 time in total.
jolson
Attack Rabbit
Posts: 2560 Joined: Thu Feb 12, 2015 12:40 pm
Post
by jolson » Mon May 18, 2015 11:56 am
Let us know if you get this working or if you run into any problems along the way. Thanks!
Twits Blog
