I did not think of switching to another port like that to isolate it. I went with 9002.
/etc/rsyslog.d/80-nagioslogserver_var_log_mailman_post
$ModLoad imfile
$InputFilePollInterval 10
$PrivDropToGroup adm
$WorkDirectory /var/lib/rsyslog
# Input for mailman_post
$InputFileName /var/log/mailman/post
$InputFileTag mailman_post:
$InputFileStateFile nls-state-var_log_mailman_post_log # Must be unique for each file being polled
# Uncomment the folowing line to override the default severity for messages
# from this file.
#$InputFileSeverity info
$InputFilePersistStateInterval 20000
$InputRunFileMonitor
# Forward to Nagios Log Server and then discard, otherwise these messages
# will end up in the syslog file (/var/log/messages) unless there are other
# overriding rules.
if $programname == 'mailman_post' then @@nagios-log1.HOSTNAMEHERE:9002
if $programname == 'mailman_post' then ~
The config in NLS:
tcp {
type => 'mailman'
port => 9002
Applied config on NLS.
Restarted rsyslog, then "tail -f /var/log/mailman/post &" and then "tcpdump -n dst port 9002" and watched. Sent test messages through mailman and I saw the /var/log/mailman/post logs entries pop up but nothing in tcpdump.
I double checked again that the other information configured under port 5544 was still going out via tcpdump and it was...
I am including my entire rsyslog.conf, maybe I am doing something else that causes this specific one to fail?
#### MODULES ####
$ModLoad imuxsock.so # provides support for local system logging (e.g. via logger command)
$ModLoad imklog.so # provides kernel logging support (previously done by rklogd)
$ModLoad immark.so # provides --MARK-- message capability
# Provides TCP syslog reception
#$ModLoad imtcp.so
#$InputTCPServerRun 514
#### GLOBAL DIRECTIVES ####
# Use default timestamp format
$ActionFileDefaultTemplate RSYSLOG_TraditionalFileFormat
$template MalformedMsgFormatter,"%timegenerated% %fromhost% %rawmsg:::drop-last-lf%\n"
# File syncing capability is disabled by default. This feature is usually not required,
# not useful and an extreme performance hit
#$ActionFileEnableSync on
## logs be world readable
$umask 0000
$FileCreateMode 0644
$DirCreateMode 0755
# log most critical and kernel messages to the console
# kern.debug is omitted so it can be used by iptables
*.crit;kern.info /dev/console
# Exclude most other stuff from logging to the console.
mail,news,lpr,cron,user.none /dev/console
local0,local1,local2.none /dev/console
local3,local4,local5.none /dev/console
local6,local7.none /dev/console
# The standard stuff that goes to /var/adm/messages.
# RHEL / rsyslog adds an "authpriv" facility that by default
# is written to a "secure" file.
# The authpriv file has restricted access.
authpriv.* /var/log/secure
*.err;daemon,auth.notice;mail.crit;news,user.none;mark.debug /var/log/messages
# This exclusion is arguably superfluous sinc admin2/loghost runs
# syslog-ng with its own config file. We will need to be careful to
# update this to reflect new/changed loghost(s). Below is a second
# stream sent to lab3 for testing
# central logging server
*.debug @10.2.XX.XX
& @10.1.XX.XX
# send all 'auth' stuff to the authorization log
auth,mark.debug /var/log/auth/debug
# local facilities were once assigned to different overlay groups
# local0 - currently unused (except for scd-dns*?)
# local1 - veriodns
# local2 - it provisioning
# local3 - it provisioning
# local4 - it provisioning
# local5 - currently unused (avoid this one - see below)
# local6 - Net-SNMP snmpd
# local7 - currently unused
# Local.Info
local0.info;mark.debug /var/log/local0/info
local1.info;mark.debug /var/log/local1/info
local2.info;mark.debug /var/log/local2/info
local3.info;mark.debug /var/log/local3/info
local4.info;mark.debug /var/log/local4/info
local5.info;mark.debug /var/log/local5/info
local6.info;mark.debug /var/log/local6/info
local7.info;mark.debug /var/log/local7/info
# Local.Debug
local0,mark.debug /var/log/local0/debug
local1,mark.debug /var/log/local1/debug
local2,mark.debug /var/log/local2/debug
local3,mark.debug /var/log/local3/debug
local4,mark.debug /var/log/local4/debug
local6,mark.debug /var/log/local6/debug
local5,mark.debug /var/log/local5/debug
local7,mark.debug /var/log/local7/debug
# various daemons, such as sshd and ftpd (if ever running)
# includes log entries from alert.pl as well now, msw 10/2007
daemon,mark.debug /var/log/daemon/debug
# RHEL default rsyslog has
# mail.* -/var/log/maillog
# The - indicates that the file should not be sync'd after each message,
# saving time and disk I/O for files that get a lot of messages, but at
# the potential risk of message loss if the host crashes.
mail.notice;mark.debug /var/log/mail/notice
mail,mark.debug /var/log/mail/debug
# General stuff
kern,mark.debug /var/log/kern/debug
lpr,mark.debug /var/log/lpd/debug
syslog,mark.debug /var/log/syslogd/debug
user,mark.debug /var/log/user/debug
uucp,mark.debug /var/log/uucp/debug
# Catch cron info
cron.info;mark.debug /var/log/cron/info
# Notify the operator, if he's logged in.
*.alert;kern.err;daemon.err;user.none operator
*.alert;user.none root
# Send emergency messages to everyone that is currently logged in.
*.emerg *
# For 'user' facility messages that aren't quite emergencies but are
# important.
user.err /dev/console
user.err /var/adm/messages
user.alert root, operator
# rsyslog foo:
# ### begin forwarding rule ###
# The statement between the begin ... end define a SINGLE forwarding
# rule. They belong together, do NOT split them. If you create multiple
# forwarding rules, duplicate the whole block!
# Remote Logging (we use TCP for reliable delivery)
# An on-disk queue is created for this action. If the remote host is
# down, messages are spooled to disk and sent when it is up again.
#$WorkDirectory /var/spppl/rsyslog # where to place spool files
#$ActionQueueFileName fwdRule1 # unique name prefix for spool files
#$ActionQueueMaxDiskSpace 1g # 1gb space limit (use as much as possible)
#$ActionQueueSaveOnShutdown on # save messages to disk on shutdown
#$ActionQueueType LinkedList # run asynchronously
#$ActionResumeRetryCount -1 # infinite retries if host is down
# remote host is: name/ip:port, e.g. 192.168.0.1:514, port optional
#*.* @@remote-host:514
# ### end of the forwarding rule ###
# Include all config files in /etc/rsyslog.d/
$IncludeConfig /etc/rsyslog.d/*.conf
As a comparison here is my working apache_access version of this.
$ModLoad imfile
# Input for apache_access
$InputFileName /var/log/httpd/access_log
$InputFileTag apache_access:
$InputFileStateFile nls-state-var_log_httpd_access_log # Must be unique for each file being polled
# from this file.
# overriding rules.
if $programname == 'apache_access' then @@nagios-log1.HOSTNAMEHERE:5544
if $programname == 'apache_access' then ~
