nrpe configure without ssl on Solaris 10
grenley
Post by grenley »
Hi.
I am trying to compile nrpe on Solaris 10.
I have been unable to make it compile with ssl.
That's fine; I'm happy to go without.
I can't get it to make even when I configure with --disable-ssl
Several errors in nrpe.c are returned.
./nrpe.c:103: error: syntax error before '*' token
./nrpe.c:1799: error: syntax error before '*' token
./nrpe.c: In function `complete_SSL_shutdown':
./nrpe.c:1816: error: `ssl' undeclared (first use in this function)
./nrpe.c:1816: error: (Each undeclared identifier is reported only once
./nrpe.c:1816: error: for each function it appears in.)
They're documented in a couple of forum posts from 2013 and you accepted it as a bug.
Do we have a fix yet?
Rick
Re: nrpe configure without ssl on Solaris 10
Can you describe all of the steps you took to compile NRPE on Solaris 10? Did you follow similar steps, as described in this guide?
Usually you see similar errors if openssl-devel package is missing. I'm not sure how this is called in the Solaris land.
Can you provide us with links to these forum posts?
grenley
Post by grenley »
Sure. Here's one: http://support.nagios.com/forum/viewtop ... =7&t=21688
I did, in fact, use that procedure (and a few others I found online). Got boatloads of ssl-related errors on the compile.
That's why I decided to go without.
jdalrymple
Skynet Drone
Post by jdalrymple »
It's probably easier to just make ssl work - but if you don't want to, comment out the following lines: (I used 2.15 so my line numbers may differ slightly)
Line 103
void complete_SSL_shutdown( SSL *);
Line 1799 - 1818
void complete_SSL_shutdown( SSL *ssl) {
                Thanks to Jari Takkala ([email protected]) for the following information.
                We need to call SSL_shutdown() at least twice, otherwise we'll
                be left with data in the socket receive buffer, and the
                subsequent process termination will cause TCP RST's to be sent
                to the client.
                See http://bugs.ruby-lang.org/projects/ruby-trunk/repository/revisions/32219/diff
                for more information.
        int x;
        for( x = 0; x < 4; x++) {
                if( SSL_shutdown( ssl)) break;
Note that you can't comment with /* - */ unless you get rid of the existing comments in the middle. You can just delete the lines if you prefer not to comment them out.
grenley
Post by grenley »
That worked.
Thanks very much.
abrist
Red Shirt
Post by abrist »
Great! Locking thread.
