No data available
rafdwo
No data available
Post by rafdwo »
I have set NetFlow from my switch to nagiosna for 72h, I am able see that source data increase, however nagiosna does not show anything (few months already). Version upgrades did not helped, Netflow tested with local computer is fine. Nagiosna is working on the same machine as Nagiosna.
cat /etc/sudoers.d/nna_conf
Defaults:%nnacmd !requiretty
Host_Alias HOST = localhost
Cmnd_Alias LIST = /sbin/iptables --list
Cmnd_Alias SAVE = /etc/init.d/iptables save
Cmnd_Alias UPDATE = /sbin/iptables -I INPUT -p udp -j ACCEPT --dport *
Cmnd_Alias DAEMON = /usr/local/nagiosna/bin/nagiosna *
%nnacmd ALL=(ALL) NOPASSWD:LIST
%nnacmd ALL=(ALL) NOPASSWD:SAVE
%nnacmd ALL=(ALL) NOPASSWD:UPDATE
%nnacmd ALL=(ALL) NOPASSWD:/bin/kill *
%nnacmd ALL=(ALL) NOPASSWD:DAEMON
Any idea what is wrong.
Re: No data available
Can you run the following commands on the Nagios NA server and show us the output?
date
file /etc/localtime
grep "date.timezone =" /etc/php.ini
Check the time on the sending device and your workstation.
Run the following command:
tcpdump src <sending device ip> and port <listening port>
wait for a while until you get some output, copy & paste the output, so that we can review it.
Also, show us the output of the following command:
ll -d /var/www/html/nagiosna/www/media/js
rafdwo
Post by rafdwo »
#date
Fri Jun 5 10:39:30 EDT 2015
#file /etc/localtime
/etc/localtime: symbolic link to `/usr/share/zoneinfo/US/Eastern'
#grep "date.timezone =" /etc/php.ini
date.timezone = US/Eastern
#tcpdump src 192.168.100.3 and port 9991
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
10:41:37.841647 IP 192.168.100.3.57511 > tor-nagios-01.osm-oev: UDP, length 1416
10:41:37.842934 IP 192.168.100.3.57511 > tor-nagios-01.osm-oev: UDP, length 1416
10:41:38.841580 IP 192.168.100.3.57511 > tor-nagios-01.osm-oev: UDP, length 1416
#ll -d /var/www/html/nagiosna/www/media/js
drwxrwxr-x 4 root apache 4096 May 28 14:19 /var/www/html/nagiosna/www/media/js
Inside /usr/local/nagiosna/var/backend.log I see error:
2015-06-05 10:40:01 ERROR : Error reaping file: unknown option '--no-overwrite': Traceback (most recent call last):
File "/usr/local/nagiosna/bin/reap_files.py", line 141, in <module>
main()
File "/usr/local/nagiosna/bin/reap_files.py", line 135, in main
update_views(directory, flowfile, sid, ABS_FLOWFILE)
File "/usr/local/nagiosna/bin/reap_files.py", line 111, in update_views
initialize_source.create_bandwidth_db(ABS_VIEWPATH, '%s-bandwidth.rrd' % name)
File "/usr/local/nagiosna/bin/initialize_source.py", line 60, in create_bandwidth_db
'RRA:HWPREDICT:1440:0.1:0.0035:288' )
error: unknown option '--no-overwrite'
What is the make and manufacturer of your switch and what version of Neflow is it using?
Can you run the following command from a shell on the NA system and post back the output?
rrdtool -v
rafdwo
Post by rafdwo »
#rrdtool -v
RRDtool 1.4.8 Copyright 1997-2013 by Tobias Oetiker <[email protected]>
Compiled May 28 2015 14:14:01
Netflow ver. 9, we already tried 5 with the same issue
Switch:
Cisco 3750, running on OS Version 12.2(44)SE5
jolson
Attack Rabbit
Post by jolson »
I would like you to try recompiling nfdump on the Nagios Network Analyzer server in question.
wget http://sourceforge.net/projects/nfdump/files/stable/nfdump-1.6.13/nfdump-1.6.13.tar.gz/download
tar xzf download
cd download
./configure --enable-sflow --enable-nsel
make
make install
After the compilation is finished, let us know if events start populating in the Web GUI properly.
Twits Blog
rafdwo
Post by rafdwo »
Still nothing.
When I trying to run report for view other than default I am getting now:
There was an error running nfdump command: /usr/local/bin/nfdump -M '/usr/local/nagiosna/var/3745Corporate/views/192.168.100.3/' -R . -t '2015/06/04.15:07:02-2015/06/05.15:07:01' -N -n '5' -s 'srcip/bytes' -o 'csv' 2> /dev/null
jolson
Attack Rabbit
Post by jolson »
Try restarting the Nagios NA services and checking for those errors once more.
service nagiosna restart
Let us know if data doesn't appear within about 30 minutes.
Twits Blog
rafdwo
Post by rafdwo »
It did not helped.
[image]na2.png[/image]
[image]na1.png[/image]
ssax
Dreams In Code
Post by ssax »
Where are you seeing that error?
Just to make sure that nfdump was upgraded, please run these commands and post the output:
which nfdump
nfdump -V
