Split Alerting schedules
Francois_Silanis
Post by Francois_Silanis »
Hello guru's!
i am trying to fiugure out something but i can't find a solution or a way to do it. so i am asking your help.
i already have a infra in place, monitored by nagios, with different schedules and different notification methods. production are monitored 7/24, alerting 7/24 via email and SMS thats fine. i have DEV servers, monitored 7/24, alerting via work hours only via email and sms.
what i want to achieve is to get DEV servers, send email 7/24 regardless and keep SMS only workhours. or the other way, i want email sent regardless of shchedules and notification period.
i dont think this is doable... does some of you have a thoughts on the subjects, would be appreciated.
p.s. i am using nagios core 3.5.1
best regards friends.
ssax
Dreams In Code
Re: Split Alerting schedules
Post by ssax »
If you have multiple contacts like jdoe and jdoe_sms you could use multiple host/service escalations that would observe the timeperiods.
You can read more about them here:
http://nagios.sourceforge.net/docs/nagi ... tions.html
http://nagios.sourceforge.net/docs/nagi ... escalation
Francois_Silanis
thanks for the information! i finaly managed to just remove all non critical from pager instead. and keep non critical email only. this work perfect for me!
i have another question tho. what is the difference between core 3 and core 4 ? interface is exactly the same, is there a version history i can read somewhere?
This should give you a pretty good overview of the changes: http://nagios.sourceforge.net/docs/nagi ... tsnew.html
Basically: Speed.
