Hi All,
is it possible for nagios xi to fetch the mount points automatically when you add a new linux host.
RIght now i have to manually add the mount points for each host which is a bit difficult if you have more number of hosts.
Kindly help
Regards
Venki
Fetching linux mount points automatically
- Box293
- Too Basu
Re: Fetching linux mount points automatically
What check / plugin are you using to monitoring mount points?
i am using snmp protocol.
jdalrymple
- Skynet Drone
Not today. This feature is coming soon though. The development work is done on it and I've seen it function with my own two eyes.
It will be coming with the next major release.
any update on this request
What version of XI are you running?
Former Nagios Employee.
me.
me.
nagios xi R 2.7
snmp protocol
snmp protocol
This has been added, however is not available to version below 5.1.0
If you upgrade your XI server to the latest you will have the functionality in the SNMP Wizards
