How to install ndoutils on nagios 4.0.8
abrist
Red Shirt
Re: How to install ndoutils on nagios 4.0.8
Post by abrist »
Well, you could do a count on the nagios_logentries or any of the other tables:
echo "select count(*) from nagios.nagios_logentries;" | mysql -u<db_username> -p<db_password>
yunushaikh
Post by yunushaikh »
Thank you very much Sir..
You helped me lot. I will let you know if I have any other doubt. You are doing great job.
yunushaikh
Hello Sir,
I have started ndo2db daemon using init script and it is running also but Nagios is not writing to database. I verified by query given by you.
Can you help me where to check the logs and what is the issue with it.
Thanks for that
yunushaikh
Hey I was able to configure ndoutils
If the issue is resolved, shall we close this post?
yunushaikh
Yes Sir.. Please close this thanks..
