Trying to build out a new VM out on the latest Cent6.6 image that our linux engineers have published for production. With XI 2014r2.6 source install, I keep hitting this error on 1-prereqs:
Error: php54w-common conflicts with php-common-5.3.3-40.el6_6.x86_64
You could try using --skip-broken to work around the problem
** Found 1 pre-existing rpmdb problem(s), 'yum check' output follows:
rhnsd-5.0.15-1.el6.i686 is a duplicate with rhnsd-5.0.14-1.el6.x86_64
I can't figure out where it's trying to pull php54w
