Need better graphing
jolson
Attack Rabbit
Re: Need better graphing
Post by jolson »
If you are part of a commercial organization, I would assume that the answer is no.
Is there any better options than this?
If this is a problem for you, is it a possibility for you to upgrade to our paid solution (Nagios XI)? Nagios XI makes use of highcharts quite well. Otherwise I think you're stuck with PNP/RRD graphs.
Twits Blog
yunushaikh
Post by yunushaikh »
Ok Sir, Thanks for your answer. You can lock this thread.
I will check if we have to take a license. Thanks a lot for your clarification.
jolson
Attack Rabbit
Post by jolson »
No problem - have a nice day!
Twits Blog
