Hello Experts,
I have configured a nagios plugin check_snmp_int_v1 to monitor network interfaces. Now the problem is that this plugins look for all the interfaces present on the server and suppose if any one of them is not connected it gives me critical error. Is it possible to monitor specific network interfaces or is there any other plugin which can only monitor the interfaces we want to monitor.
Thanks for you help.
Example of present output
em1:DOWN, lo:UP, p7p2:DOWN, p3p2:DOWN, p7p1:DOWN, em3:DOWN, bond0:UP, p3p1:UP, em4:DOWN, em2:UP: 6 int NOK : CRITICAL
Monitor only the required network interfaces
yunushaikh
jdalrymple
- Skynet Drone
Re: Monitor only the required network interfaces
It appears to me that the plugin you used supports regex filtering:
Is this the plugin?
If so try adding something like -n "bond0|p3p1|em2"
http://nagios.manubulon.com/index_commands.html#interfaceIf so try adding something like -n "bond0|p3p1|em2"
yunushaikh
Thanks sir,
It worked. Thanks a lot.
